shortcut for "view all tracks and regions"?
hi all,
i'm back to pro tools after a 4 yr hiatus, and everything is going very smoothly, except i cannot remember one of my favorite commands. it was something like "show all tracks and regions in edit window" it would show the tracks and regions in their entirety from beginning to the end of session. i found the "option+a" command that vertical zooms to show all tracks, but i still have to scroll up or down to see some of them. how can i get the edit window to show all active tracks and regions without having to scroll? any ideas? thanks. |
Re: shortcut for "view all tracks and regions"?
alt + a
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
thank you. i'll check it out.
actually thats the command i cant get to work alt+a" (same as "option+a" right?).
when i "option+a" i still have to scroll vertically to see all of my tracks if i have a track heavy session. i need a command that shows the full tracks/regions of the session both horizontally and vertically. i'm on a macbook pro if that helps. |
I know how to do it in 2 steps...
control+option+command+up arrow for the vertical, then... double click on the zoom tool for the horizontal.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
i'll try it today and see what happens. i was hoping for 1 step, but this doesn't look too bad.
thanks |
Midi Clips View Problem, option + "-" keyboard shortcut broken | kingtinker | Pro Tools 10 | 5 | 09-25-2016 01:47 PM |
Shortcut for "view channel strip" command? | Zakazastar | Tips & Tricks | 22 | 08-25-2014 10:13 AM |
Toggle Track view ("Opt"+"-") doesn't work | LukeFromBerlin | macOS | 3 | 04-01-2012 04:43 AM |
KB shortcut to delete all "old" regions in a session? | Hercules | Pro Tools 9 | 1 | 09-21-2011 05:10 PM |
If I "Remove Unused Regions" after "Consolidate", track won't play? | el biciclista | Pro Tools TDM Systems (Mac) | 10 | 04-02-2003 10:17 AM |
