Old 11-03-2011, 06:29 AM
redchair redchair is offline
Default firewire help digi 003 to mac pro
digi 003 LE factory PT 8.0 to mac pro
mac specs
Processor 2 x 2.4 GHz Quad-Core Intel Xeon
Memory 6 GB 1066 MHz DDR3
Software Mac OS X Lion 10.7.2 (11C74)
with:two 800 firewire ports
Just picked up my first ever mac and want to set up pt for the first time. problem, the mac pro's come with 800 firewire ports. So , i need a recommendation for what adapter i need to purchase on the mac store site. They have there own adapter 800 to 400 or the belckin products which is a little bit more pricey. Does it matter for performance.
Redchair Recordings
Old 11-03-2011, 08:52 PM
BC_Nash BC_Nash is offline
Default Re: firewire help digi 003 to mac pro
Hi Redchair!
Shouldn't matter. Try online for best prices. I usually go to a local Apple or Mac Outfitters.
Good luck!
Old 11-03-2011, 09:11 PM
@ndy's Avatar
@ndy @ndy is offline
Congratulations. I would go for a 400->800 cable and not the adapter. It doesn't need to be expensive, however I wouldn't buy the cheapest. I am using OWC cables which are inexpensive but not cheaply made.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Digi 002 firewire??? Drespencer84 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-11-2010 10:20 AM
Digi 002 Firewire 400speed not accepted by new Mac Pro Firewire 800speed ports AncientMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2010 09:31 PM
Firewire 800 and DIGI 002 irishharry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-05-2010 12:28 PM
DIGI 002 & DV firewire out EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-29-2004 07:22 AM
FIREWIRE AND DIGI 001 CHICAGO ENG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-08-2000 03:53 PM
