Raw vocal issue???
I checked some Youtube video demo about my mic AKG Perception 820 Tube. They said that they didnt use any effect (Comp, EQ, etc). Just straight MIC-> Preamp -> Audio Interface (They didnt mention what kind). I can hear that it sounds so flat and natural, flat high ends, flat low ends, balanced. And also, the vocal came out so that it occupies only a tiny bit of space and still have room for other tracks to be added. My setup is the same. AKG 820 - > Digidesign PRE - > Digidesign 96 INterface. No effects. BUt the result came out that theres a lot of sibilance coming out from the vocal. The settings from my preamp are all default, no EQ, no Low Cut. The high ends are too high and also when you hear it, it takes a lot of space from the mix, it sounded that it took the whole spectrum. I know I can probably fix it by adding effects but it should be the same as the one above. Im having this issue for a long time and its hard to mix this way. |
Digi 003 Vocal Quality Issue | ThaPath | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-18-2011 02:03 PM |
Elastic Pitch - Vocal "Formant" Issue | Torchlight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-04-2009 07:20 PM |
Vocal/panning issue - plz help! | LykanKhan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-08-2009 09:48 AM |
MBox2/Windows Simple Vocal Recording Issue | SessionSinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 01-02-2007 11:11 AM |
Vocal Rack VST to RTAS Plugin Issue | bo fitz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-21-2005 10:35 PM |
