Old 02-21-2008, 11:09 PM
cajonezzz cajonezzz is offline
Default does a PCI-e accel cards outperform PCI-accel?
Just wondering if there was any functional difference between PCI-e based Accel cards and PCI-(x) ? any benchmarks done here?
Old 02-22-2008, 02:38 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: does a PCI-e accel cards outperform PCI-accel?
PCIe have very slightly "less" power than PCIx.......
Differences Between PCIe and PCI-based Pro Tools|HD Systems
• The PCIe HD Accel card uses a combination of the chip-types used on the Core and
Accel PCI cards
• This gives the PCIe version more processing power than a PCI Core, "and a little less
than a PCI Accel."
• In larger systems (HD 3 and greater), this difference is insignificant.
• In smaller systems (HD 1, HD 2) there are some noticeable differences, but for many
typical sessions using a combination of different algorithms, the differences are
minor.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-23-2008, 12:01 PM
Akat-1 Akat-1 is offline
Yeah but the pcie core cards have more processing power than the PCIx core cards and can also run Accel only plug-ins.
Here's the tech doc's..
web page
Old 02-23-2008, 12:45 PM
kittonian kittonian is offline
The way it was explained to me by Digi was if you go with an HD1 comparison, the PCIe will be more powerful than the PCI because the CORE card on the PCIe side is actually an Accel card, whereas the PCI version is not.
However, the PCIe is slightly less powerful than the PCI cards are and if you go with an HD|3 Accel rig, no matter if it's PCI or PCIe the power will be virtually identical between the two. So, it all evens out.
Joshua Aaron
President/Chief Eng.
AudioLot/AudioLot Studios
Pro Audio Sales/Consulting
http://www.audiolot.com
Follow AudioLot on Facebook
Old 02-24-2008, 06:21 AM
Sui_City Sui_City is offline
Craig,
Here you go:
PCI vs PCIe
Accel Cards next to other PCIe Audio Cards in the same Mac Pro for PT 10+11? relaxo Pro Tools 11 12 05-14-2020 02:05 AM
Are all pcie cord cards, accel cards? fourthtunz Pro Tools TDM Systems (Mac) 2 11-20-2011 08:41 AM
HD 3 Accel PCIe = 2 Accel Core + 1 HD Accel???? Eduardo Apolonia Pro Tools TDM Systems (Mac) 24 08-04-2007 02:20 PM
HD3 NON ACCEL. +Duende or add accel cards? cajonezzz Pro Tools TDM Systems (Mac) 2 05-05-2006 03:40 PM
Can you mix Accel cards with non-Accel Processors? Riad Pro Tools TDM Systems (Win) 8 12-29-2004 11:20 AM
