Hey Allen
I'm hitting the limitations within my system on some mixes I'm working on for this band. Tons of tracks and lots of plugs. Of course, I'm consolidating where possible, but it's starting to get frustrating. Can I expect noticeable performance gains by upgrading my mbo and processor to your recommended setup (AMD 64)? If so, is that all I'd need to upgrade? I basically have the under $600 setup currently as far as mbo, cpu, memory.
Also, I'm probably going to go to the 002R this summer, how will that effect things (I already have a firewire card) as far as performance? Thanks
PT Ultimate 2020.3.0 1 HDX Card Lynx Aurora 16 (2) Windows 10 Pro 1909 ASUS X-99 II Intel i7 32GB RAM Gigabyte GeForce GTX 1050 Ti 4GB www.doylemusic.com |
Re: Hey Allen
What clock and multiplier are you using with the 2500+? If you're prepared to replace the MOBO and CPU with the AMD 64 3500, which will definitely boost your performance, it might be worth trying to overclock the one you've got first.
Quad 2.5 G5, 4.5G RAM |
Re: Hey Allen
It's already overclocked per Allen's recomendations.
Re: Hey Allen
I haven't seen anyone with the new AMD 64 3400+ or above run out of processing power yet. There is a big difference from what you are using and the AMD 64 processors. I think you can upgrade now for around 300.00 with the 3400+/K8V-X combo.
Allen |
Hey Allen | Phil O'Keefe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-31-2004 09:59 PM |
To Allen | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-17-2004 01:58 PM |
Allen... ALLEN!!! NEW STANDARD 32 + 31 | Keith Owens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 02-11-2004 08:26 PM |
Allen, need your help... | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-07-2002 03:19 PM |
Hey Allen... | G.roots | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-20-2002 02:50 PM |
