  #21
Old 08-18-2022, 08:29 AM
JoeTools1963's Avatar
JoeTools1963 JoeTools1963 is offline
Default Re: Pro Tools 2022.7 is out now
For those of us that are Post Production oriented, Re-Mixers, Sound Designers, Dialogue Editors....etc, is there any feedback picture and sync related?
Any issues with plugins, AAF imports etc????
Cheers
JT
Joe Tools
Re-Recording Mixer/Sound Designer
Nova Scotia Canada
OS Ventura 13.0
Pro Tools Ultimate 2022.12
Mac Studio Max 32GB Ram
OS 10.8.5
Pro Tools HD Accel Version 10.3.8
Mid 2012 Mac Pro 5,1 32GB Ram
  #22
Old 08-21-2022, 02:43 PM
jeff markham's Avatar
jeff markham jeff markham is offline
The midi editor has some serious issues. Using the grabber tool in the midi editor, grabbing a note an moving it does not work. It also doesn't sound when pressing the note.
In the velocity editor, I can hear the volume of the note changing as I move the diamond up and down, but the visual doesn't show a change.
I wound up using the score editor to move the note, but it too, doesn't show the note on the stave where it is sounding.
So I think 2022.7 is a no-go if you edit MIDI.
  #23
Old 08-21-2022, 03:39 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Yes. MIDI is totally useless in 22.7. But it's been discovered that switching temporarily to sample mode can enable you to edit midi notes. This has now enabled me to use 22.7 again.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
  #24
Old 09-01-2022, 02:28 PM
Thanks for that .. how on earth did that release get through QA.
  #25
Old 09-01-2022, 02:52 PM
Well .. interestingly .. Avid Link showed an update on 22.7 .. even though they didn't bump the revision number?
Anyways, after it installed, MIDI started behaving again. .. only weird thing was it removed PT from the Dock (Mac).
  #26
Old 09-02-2022, 08:40 AM
Yes, there was a glitch with the first installers released for 2022.7, as they didn't include certain bug fixes. There was a second installer released that fixed those omissions. 2022.7.105, I believe. There is a sticky thread about it in this forum.
Here is a link to page 2 where Jeffro explains:
https://duc.avid.com/showthread.php?t=421232&page=2
Scott Gatteño
  #27
Old 09-03-2022, 08:15 AM
Sean Read Sean Read is offline
Thanks for this
I'm having the same problems unable to select or edit notes in the MIDI editor
Pro Tools 2022.6 won't launch Scheak80 Windows 5 07-27-2022 09:15 AM
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
MP3 Conversion Quality with Pro Tools 2022 x Pro Tools HD10.3.10 Alécio Costa Pro Tools 4 06-01-2022 11:58 AM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
Pro Tools Subforum - 2022 or ? Tweakhead General Discussion 22 05-02-2022 12:35 PM
