Old 04-30-2009, 04:16 PM
dj wizz dj wizz is offline
Default PT 8 LE Crash Every Time I Drag File From Workspace About 2 Give UP!!!!!
iMac 2.3GHz Intel Core 2 Duo
Mac OS X 10.5.6
4GB 800Mhz DDR2 SDRAM
250GB Internal Mac HD
750GB Iomega External HD
PT8 LE, MBOX2 Mini.
This is really annoying now and i cant figure out why PT 8 LE crashes every time i drag and drop anything into the edit window from workspace.
I have used the pro tools pref and database helper to delete all prefs, database, and volumes folders... heck i deleted the lot. I also went to disk utilities and verified and repaired disk permissions for both my volumes.... So why does this still happen!!?!?!?!?!?!?!?!
Does this not happen for anyone else at all after doing all this
Im almost at the end of this BS its ridiculous!@£$%$£@!!!
Old 05-01-2009, 02:11 AM
Default Re: PT 8 LE Crash Every Time I Drag File From Workspace About 2 Give UP!!!!!
for gods sake, i must be the only person hu this problem persists with!
this is a serious flaw in the digidesign working... i was singing PT's praises to no end until this started happeneing and now it seems ive uncovered a wealth of problems with this system... the advantages workspace gives u was one of the main reasons i switched to PT8 from cubase... now im starting to think it wasnt such a good idea.
PLEASE HELP!!!!
Old 05-01-2009, 08:36 AM
jmitchell1532 jmitchell1532 is offline
Post a Sandra report so we can get more info on your system.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 05-01-2009, 09:26 AM
DigiTechSupt's Avatar
When it crashes - what happens? Do you get an error message? Does it happen when dragging in files from a particular drive (in other words, have you tested bringing in files from both drives, to see if one crashes and the other doesn't)?
Have you verified that ALL installed plug-ins are compatible?
Pro Tools Plug-In Compatibility Grid
Do you have any other devices attached to the computer? Which ports do you have your drives and MB2M connected to? What types of files are you trying to import?
The more info you can provide, the easier it is to troubleshoot. And, fwiw, I cannot reproduce the problem you're describing on the iMac on my desk.
Also, have you updated to cs2 yet?
Avid Audio Tech Support
Support FAQ
Sandra is only for PC's - this person is on a Mac.
Support FAQ
Old 05-01-2009, 09:33 AM
Sometimes I forget which board I'm on. Haha. Thanks.
Jon
Old 05-01-2009, 11:45 AM
sharpo07's Avatar
sharpo07 sharpo07 is offline
I used to have that problem in PT 7.4 for PC and I tried everything. I just left the workspace alone and tried alternative methods for doing what workspace did. Haven't tried it in PT8 again cause of what happened in PT7....so no you are not the only one...
Old 05-01-2009, 12:54 PM
davidman davidman is offline
Hi mate, this may or may not help your cause, but as the above poster stated, I have also had this very same problem, albeit on a PC running XP and PTLE 7.3 (possibly 7.4). When relinking files, dragging and dropping from the workspace, importing files - all caused my computer to crash.
I got to the bottom of it eventually, and it was my graphics card that was causing the problem. I installed an updated driver and all was sorted. Never happened again since.
I know you are using a Mac, but there is a slight possibility that it could be the same cuase.
Hope you get it sorted anyway.
Old 05-03-2009, 10:22 AM
Sunzate Sunzate is offline
I have the same problem (10.5.6, PT LE 8cs2). I have removed all unqualified plugins, trashed prefs, reinstalled, and followed all troubleshooting instructions. My protools doesn't "crash" per se, but the file importing process causes a spinning beach ball, and the file arrives 2-3 minutes later.
The only thing I haven't done is reinstall the OS.
When you do that, does it preserve all of your applications and user settings etc? i.e. is it a big pain in the ass?
A
Adam White, composer.producer.engineer
www.studiocat.ca
Old 05-23-2009, 02:42 PM
Digi,
I have reason to suspect that Structure Free is causing these delays/wheel of death/crashes.
A
www.studiocat.ca
PT 11.1.2 - Drag from workspace willeyh Pro Tools 11 3 02-03-2014 04:50 PM
Drag Song From Workspace CD Drive, vs. File > Import > Audio ? taylor4814 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-17-2011 11:35 AM
Help! 45 second delay everytime I drag a .wav file in from Workspace superfiction macOS 21 06-12-2011 04:10 PM
Cannot drag wav file from workspace into session paulwilks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-17-2011 05:22 AM
Stereo File Drag 'n Drop from workspace bug? Rich Breen Pro Tools TDM Systems (Mac) 0 11-09-2004 01:01 PM
