Old 12-27-2002, 01:48 PM
facethemusic facethemusic is offline
Default Step-time drum patterns
Can anyone explain how to QUICKLY create step-time drum patterns with ProTools LE? I bought the Digi001 one and a half years ago and I'm still using a Roland MC50 to step-time drum patterns that I need for sequencing. I can't seem to use the Edit window (pencil) like I should at this point.
Old 12-27-2002, 06:26 PM
Homebelly Homebelly is offline
Default Re: Step-time drum patterns
There is no STEP record function in PT,,wish is a bit of a bummer in my opinion,,however,,if you highlite a region and then set PT to loop record you can then assemble a drum track prety quickly,,the trick is to keep your regions small,,i tend not to work on regions of more that two bars,,,what would make this methode even more workable would be to be able to select grid resolutions from the key board,,
re BFD: just drum kits or patterns as well? Calon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-11-2011 02:57 AM
Strike Drum Patterns jPaul Virtual Instruments 2 02-03-2011 05:09 PM
Realistic MIDI drum patterns. Maars MIDI 5 04-01-2009 09:14 AM
Stike and HipHop drum patterns ircswh Virtual Instruments 0 06-04-2007 02:28 PM
best way to record drum patterns moodswing 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-10-2001 01:16 PM
