Best Settings To Bounce Out An MPEG4 ?
Hola. .
There's probably a post about this somewhere here, but I have failed to find it. . I have a session that contains a Pro Res 422 HQ 1920 x1080 25fps. I have finished the mix & want to send out a reference MPEG4 for the producers to see. Does anyone have any particular advice as to the Quicktime settings ? Much appreciated . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Re: Best Settings To Bounce Out An MPEG4 ?
I'll preface this by saying I'm not a video editor so I don't really care about the visual quality or artifacts
I've been using VBR with a target bitrate of 4Mbps and max of 5. It will only do PCM audio. Which is good for approvals as long as file size isn't an issue. I'd like to see Avid add H265.
~Will |
Do you have Video Compression Software or are you talking about doing it from PT?
I always bounce it out w/o changing the video and then using something like FFWorks, compress it down using a Preset. |
Here's a simple option. Make sure your audio bounce is exactly the same length as the picture. Do an audio only bounce. Use Shutter Encoder (an excellent free app that does several cool things BTW), and use the replace audio function. The video is unchanged, but the audio mix is now new. Viola.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Yes, thanks, I usually do the same using QT Pro, but in this instance, I have had to make a timeline edit to the picture, so need to bounce out video too. My question was really geared towards the video settings available in PT. When the project is properly finished, I plan to export "same as source" video with 48/24 wav audio giving me a "full fat" master to then use to make mpeg-4 or H264 movs that can be used to send out tasters. .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ Last edited by priorytools; 12-14-2020 at 08:15 AM. |
I know this is a monthly fee after a 30 day trial, but it you are in a pinch. this is the best way to go.
I used it and it works really well and does a great job on deliverables. From my editor, who says it covers all of the bases. https://www.adobe.com/products/media-encoder.html G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Moving forward,(setting up new Mac Pro with Catalina on) I am getting to know DaVinci Resolve which I plan to use instead of QT Pro. https://www.blackmagicdesign.com/pro...avinciresolve/ Considering it's free it's quite remarkable. .
Bounce to Quicktime - useful settings | dopplah | Post - Surround - Video | 26 | 11-12-2006 06:34 PM |
creating .mov/mpeg4 file from dvd - other ways? | 1tonstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-09-2006 10:08 AM |
importing mpeg4 files into pro tools | maxi-milli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-09-2006 05:11 PM |
Importing mpeg4 files to ProTools LE | SeeHanda | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-31-2003 05:54 PM |
New music and short mpeg4 video added to www.danniielle.com | Doc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-31-2001 05:42 AM |
