access violations and C++ Runtime errors
I wanted to make a new post with this problem because I feel that there is no real answer to solving it. Basically my power harness was failing for a bit, then I started getting access violation/C++ Runtime errors, so then I put the new power harness in and I still got the errors.
Here is some more detail: -Power harness was failing, got software errors (access violation errors upon opening, creating, and/or saving sessions, and C++ runtime errors on startup that would shut down PT) -Put in new harness and fixed power problem, but still got the same software errors -Uninstalled/reinstalled PT6.1, still got the errors, installed 6.1.1, still got the errors -Reformatted hard drive, did a fresh install of XP and PT and still got the same errors -I don't have the dfx plugin, so that wasn't causing it -I tried a new firewire cable, that didn't fix it The only thing that I can think of that's causing it is the 002r itself, but how can that even be? How could that hardware cause C++ Runtime errors in ProToolsLE.exe? I am about to lose my mind.... Honestly, how can this even happen?? I've NEVER gotten these errors before in my life and now there back even after I reformat. Am I missing something here? Is there anything that I'm not being told or finding when I'm searching the DUC? I already lost 1 client so far because of this and I just want to get this fixed before I lose another. Does anyone know ANYTHING else I could try or what I should do next? Thanks, Steve |
Re: access violations and C++ Runtime errors
NOTE:
TO ANYONE THAT SEES THIS I THINK I MAY HAVE FIXED IT. IF YOUR EVER HAVING THESE PROBLEMS, DELETE YOU DIGIDESIGN DATABASES FOLDER ON WHATEVER HARD DRIVE YOU USE TO RECORD, EMPTY THE RECYCLE BIN AND RESTART! Unfortunately I lost a whole weekend in figuring this out, but it worked, and I hope it works for somebody else too! |
quote: NOTE: TO ANYONE THAT SEES THIS I THINK I MAY HAVE FIXED IT. IF YOUR EVER HAVING THESE PROBLEMS, DELETE YOU DIGIDESIGN DATABASES FOLDER ON WHATEVER HARD DRIVE YOU USE TO RECORD, EMPTY THE RECYCLE BIN AND RESTART! ================================================== ======== This all must have you frustrated a bit...no?...;-)
What's that? - That's the machine that goes "pling". Bastiaan |
Oh just a bit.. :crazy:
Was this common knowledge or what? How come it wasn't anywhere when I seached the DUC? |
Hmm... Ive seen those errors a couple times but no crashes or anything. Must try deleting the dbb folders. Good info, Bastiaan.
How about those digiprefs folders? These errors started after I jumped to 6.7, very, very seldom but I´ve seen them anyway and they have done no harm -yet.
-------------------------------------------------------------------- - i7 520 @ 3.6 GHz / P6T / XP32 / PTLE 8.01 . PT9 on Snow . - PTLE8 on a macbook. - And a bunch of miscellaneous obsolete hardware from the past. Like Mix ++++ 64 i/o with Control/24 I`m In The Band: www.ozofficial.com My guitars are in tune : http://www.truetemperament.com/site/index.php |
I started getting these errors at one point (not using 001 and I'm not sure if there is a direct connection btwn the harness issue and the errors although the failing harness may have triggered something I suppose. You resolved the issue pretty much the way that I did - dump the databases and the preferences.
Access Violations and Assertion Errors | southboundpachyderm | Pro Tools 10 | 8 | 10-11-2013 08:20 AM |
Access Violations Using Dropbox - Need Help | icenet | Pro Tools TDM Systems (Mac) | 2 | 06-22-2011 09:29 PM |
Access violations, Runtime errors, not enough memory etc | Seagate Studio | Pro Tools TDM Systems (Win) | 4 | 05-19-2010 03:08 AM |
Access Violations | Crookster | Pro Tools M-Powered (Win) | 6 | 10-17-2007 01:09 PM |
Access violations have shut me down! | Rubianes2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-07-2007 11:16 AM |
