Old 03-01-2001, 09:19 AM
cdrecords cdrecords is offline
Default mac to pc file conversion
I tranfered 24 tracks from a Tascam Recorder into studio with Pro Tools 24 Mac. Had the files saved on to CD rom. Waited for upgrade 5.1 to convert mac files into PC 001 files. I assumed they were SD II files but when I bring up the import audio conversion window and files of type drop down box no matter what format I chose the bottom message reads: This file is unreadable by pro tools. Any ideas what other possible file format could this studio have used. Their out of business so I'm in a delema, Thanks Billy
Old 03-02-2001, 11:37 AM
DigiTechSupt's Avatar
Default Re: mac to pc file conversion
-SD II files are not compatible with Windows (WAV and AIFF only). Convert the files on a Mac using Pro Tools or a stand-alone coversion utility such as SoundApp and then copy the files over to your PC.
Brent
[This message has been edited by DigiTechSupt (edited March 02, 2001).]
Avid Audio Tech Support
Support FAQ
Old 03-05-2001, 11:50 AM
Thanks Brent, What if I don't have access to a mac with pro tools?
Brent
Old 03-06-2001, 06:42 AM
-All you need is a Mac with a utility called: SoundApp. This can convert SDII files to a variety of formats, including WAV. This utility is available at:
http://www.harmony-central.com/Softw...onverters.html
-Unfortunately, I do not know of any PC utility that can convert SDII files.
Brent
Support FAQ
Old 03-06-2001, 02:28 PM
thepontif thepontif is offline
Whoa!!!!!!!!
GET MAC OPENER!!!!!!!
PTLE 5.0.1 AND 5.1 FOR WINDOWS BOTH CONVERT SDII FILES.
Install MacOpener (Dataviz). It is a driver that runs in the background in Win98/ME. Set the driver settings to give Dual CD-ROM's priority toward the Mac side.
You then have to set up the extension mapping parameters for PTLE Sessions and SDII files.
Type/Creator for PTLE 5.0.1 is PT5S / PTul
Type/Creator for PTLE 5.1 is PTS / PTul
Sound Designer II is Sd2f / Sd2a
DO NOT COPY ANY FILES FROM YOUR CD TO
THE HARD DRIVE!
Start PTLE.
Set up your session however it's going to be.
Go to Add Audio/Track
Tell it to look on the CD-ROM Drive.
Select the appropriate files.
click import and follow your nose from
there.
You must import the files directly from the CD.
-Mike Pope
[This message has been edited by thepontif (edited March 06, 2001).]
ptf File conversion jamesimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-03-2012 11:59 AM
DVD Conversion (Vob File) for PT deek Pro Tools M-Powered (Mac) 4 12-02-2009 11:38 AM
File Conversion 1511 Pro Tools TDM Systems (Mac) 8 12-02-2006 12:05 PM
SD2 file conversion Ian Wallace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-29-2006 03:28 PM
Need File Conversion Help? SteveGarman General Discussion 2 03-27-2001 09:53 AM
