  #41
Old 05-15-2023, 01:05 PM
EddieJones's Avatar
Default Re: Avid Control Frequently Disconnecting with Silicon Macs
Originally Posted by Mortal Coil View Post
Its all good eddie. I tried it out and now have my dock up and running full time now. Its nice to be able to use my dock and have access to all of my plugins at the same time! I'm sure everyone here can imagine how frustrating it would be to only be able to use a new surface or use plugins but not both at the same time. Especially when I have yet to develop a workflow on my new dock. My lack of experience with control surfaces in general played a big part in my problem with setting up my dock. And i had no idea rosetta could be used with anything besides pro tools. Next time i can't figure something out with PT i will use this forum. I usually avoid that and just try and figure it out on my own. But just to avoid any more setbacks I'm going to switch things up when needed. Thanks again Eddie!
Glad to help. Please do use this forum, there are many users that help not just me.
  #42
Old 07-27-2023, 11:26 PM
jamesa5454 jamesa5454 is offline
Hi all - I installed Eucon 2023.6 today and immediately got all sorts of connection drop outs. I have since relaunched Eucon using Rosetta and it's been stable since - early days yet (literally the first day), but it seems some sort of Silicon specific bug has crept back in...
  #43
Old 07-31-2023, 03:14 AM
I think I have falsely misidentified the issues I was having after looking around on the forums. Running in Rosetta didn't really yield any improvements on 23.6, however modifying the plist file as per Eddie's post "*******Temp fix for EUCON 23.6 slowdown********" has essentially fixed the issue.
  #44
Old 01-08-2024, 01:30 AM
bolisound bolisound is offline
Hi could you please let me know what is the step to fix the plist? I had the similar issue recently.
  #45
Old 01-08-2024, 09:27 AM
Thousand Words Thousand Words is offline
Originally Posted by audiogamble View Post
I've had a problem for quite some time that Avid Control will frequently disconnect. Closing the app and re-opening will fix it. I'm on an M1Mac MacBook Pro. My studio partner was on an intel Mac mini 2018 and never had that problem.
Recently he upgraded to the same computer as me, and the problem began happening for him too.
We're currently using an S1 paired with an iPad running avid control. We used to run an android tablet and had the same problems.
Both of us on macOS Monterey. Latest version of pro tools an EuControl.
Does anybody else have these problems in this configuration?
Hi, try setting your tablets to a static IP. I've done that, and also on the m1 macbook pro of my travel rig, and everything is much more stable, and responsive
  #46
Old 01-09-2024, 01:36 PM
EddieJones's Avatar
Install the latest EUCON instead. plist isn't needed in it.
  #47
Old 01-09-2024, 01:57 PM
Thanks Eddie, I have install the version you have mentioned, I still have the issue, I am thinking maybe it is my router, I will be purchasing a new router for EUCon, is there a list of router you would recommend?
  #48
Old 01-09-2024, 02:06 PM
EddieJones's Avatar
Type TP-Link Gaming Router into Amazon, we test with a few different ones here from them and they are great. Any current gaming router will do but obviously the higher priced ones will be faster, if you have a bigger system or want to expand in the future.
Control surface options with the upcoming Apple Silicon version? Phil O'Keefe Pro Tools 9 01-11-2023 06:32 PM
Most Waves plugins cannot be set properly from Avid control surfaces / Avid Control? XJENSEN Avid S1, S3, Dock and Control App 3 08-11-2022 06:59 AM
Spectrasonics 2.7 – adds VST3 and native support for Apple Silicon M1 Macs unkJE Virtual Instruments 0 06-17-2021 09:49 PM
Any way to temporarily bypass the Avid Fast Track Duo without disconnecting the USB? S.Clements FireWire & USB Audio Interfaces (Mac) 0 06-04-2014 10:19 AM
MC Control always disconnecting, no sync, offline RaToX Artist Series 0 03-24-2011 08:53 AM
