Old 10-13-2015, 07:15 AM
mbrizendine's Avatar
mbrizendine mbrizendine is offline
Default EZDrummer vs Reason
I just purchased EZDrummer 2, along with a few libraries. At first glance, I love the sounds, but I'm not impressed with the control. I've used Reason for a while now, and I absolutely love the control and MIDI editing capabilities. I can map out the drum tracks easily and I can export each part, individually, out to an audio file. This gives me great control over the mix, as I can adjust volumes of cymbals / snares / high hats / ghost notes individually and EQ / Compress / Apply Effects where it's needed.
What I've found with EZDrummer is that I'm stuck with the overhead mix of cymbals, with zero control in the mix (other than hours of automation that still doesn't give me individual control). I know that in a real environment, it's all about mic placement and you don't get that kind of control. But, I'm finding that I can't get my mixes right without that control.
Reason, hands down, has the best MIDI editor and export function that I've seen. But, the drum kits are horrible (especially for metal). Has anyone experienced this issue, and if so, how did you overcome / workaround it? I feel like I just wasted $250 on EZDrummer & libraries.
Thanks, in advance, for your input.
The numbers all go to eleven. Look, right across the board, eleven, eleven, eleven and... -Nigel Tufnel
Old 10-13-2015, 07:34 AM
TOM@METRO's Avatar
Default Re: EZDrummer vs Reason
EZ drummer is the introductory offering from Toontrack. Moving up to "Superior" will give you far more control.
BFD3 is amazing. Take a look at that.
I mostly use Addictive drums, it has enough control for me.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-13-2015, 08:54 AM
DonaldM's Avatar
DonaldM DonaldM is offline
The basic drum kits available in Reason for Kong and for Redrum are, as you say, not great, though there are some nice individual drum samples in both libraries and you can create your own kit. Remember too that there are any number of refills in the Propellerhead shop for both of these as well as kits for the NNXT and NN19 samplers, all of which you already have with Reason. Plus, you can download any samples to use in these kits as well. So you have a lot of versatility already with Reason and drums. There's other Refills out there that aren't sold through the P-head shop as well. You can google all that. I really depends on what you're looking for.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 10-13-2015, 08:56 AM
DonaldM's Avatar
And one other thought, you can also import drum kit samples to Structure and edit each part individually and send the audio outs individually for each part for further mixing/processing.
Old 10-13-2015, 09:08 AM
The single thing that used to bug me with EZdrummer is the amount of snare bleed into the overheads(something that SD2 allows you to adjust). My solution was to print all the drums to AUDIO tracks, then select NONE for the snare, and re-record the overhead audio.
Old 10-13-2015, 09:25 AM
nigelpry's Avatar
nigelpry nigelpry is offline
You can route EZ Drummer sounds to different outputs, so they appear on different tracks in Pro Tools.
According to this page ...
https://www.toontrack.com/product/ez...#functionality
... You have 16 outputs available from EZ Drummer.
I don't know about drum bleed into other microphones in EZ Drummer, but that's something I use in Superiori Drummer. Maybe that's available in EZ Drummer too?
If it is, then you will be able to isolate every drum instrument into its own channel in the EZ Drummer mixer, then route each of the mixer channels to a different output.
Finally, you set up extra aux tracks in Pro Tools to receive the audio coming out of each of the outputs of EZ Drummer, or audio tracks if you want to record the audio.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Old 10-13-2015, 11:09 AM
I didn't find that bleed adjustment in EZD, but EZ2 might have it(been doing mostly real drums lately)
Old 10-13-2015, 01:28 PM
Thanks for the input. I have just about every refill that Propellerhead has to offer, but I can never find realistic cymbals and the hard hitting kick drum and snare for heavier metal / djent style music. Again, I love the functionality and ease of use reason offers. I only wish that they'd come out with more modern kits catered to heavier music. The majority of the cymbals / hi hats have so much treble, you have to EQ them to the point of losing all of the dynamics. They also sound light and weak. I'll look around, though.
As far as output to individual tracks, I found a way to do that, but you get bleed and all of the cymbals are combined on a single track. It's frustrating to have the sound you want at your fingertips, but only to find you have no control of the mix.
Old 10-14-2015, 12:36 PM
DonaldM's Avatar
One possible workaround - (and I don't have EZDrummer, so I'm not sure this will work) but, if EZ allows you to solo individual drum parts, then you could solo each part one at a time and route to separate audio tracks and lay them down that way, one at a time. Be a bit time consuming, but in the end, you might have what you want for mixing and processing. I've done that Boom a few times, since there's no individual routing on that one.
Old 10-14-2015, 01:44 PM
nigelpry's Avatar
Donald, you can route individual EZDrummer mixer channels, which equate to microphones, to different tracks in Pro Tools, no problem.
The problem is that Toontrack's 'method' for presenting realism, involves including mic bleed, so snare sound in kick mics, tom sound in hi-hat mics etc.
We know that in Superior Drummer you can control mic bleed, including removing it altogether. We also know that in EZDrummer 1 you are not given that control. What we don't have is any confirmation from an EZDrummer 2 user to say whether mic bleed control is included in the new version or not.
If you can't control mic bleed, you could do multiple recording passes, as you say, but that is time consuming, and you'd still be soloing the mic not the drum.
You'd have to either drag/drop the MIDI from EZDdrummer onto a MIDI track and mute the notes you didn't want in a specific pass, or remove individual drums from the kit, so only one drum is triggered that way.
Are there any EZDrummer 2 users here who can clarify on the mic bleed question?
EZDrummer felixhamill AAX Plug-ins 2 09-28-2012 01:35 PM
ezdrummer how to 74nautique Windows 31 12-06-2011 09:52 AM
EZDrummer or BFD Eco johndavid The Drum Room 4 04-22-2011 06:51 AM
best drum trigger for EZDrummer, Reason, or Addictive Drums nicksorenson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 03-28-2010 12:30 PM
EZDrummer & PT7.4.2 top1percent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-19-2008 08:47 PM
