Old 08-21-2005, 03:49 PM
xeetstreet xeetstreet is offline
Location: Holland, MI - Osage Beach, MO - Rancho Palos Verdes, CA
Default Using 002R Mic Pre\'s with an outboard compressor..
I just bought a Drawmer compressor/gate/limiter for recording. Is there any way to use it after the 002R mic pre's but before the audio enters Pro Tools? (ei. Condenser Mic -> 002R mic pre -> Drawmer Compressor -> Pro Tools)
Thanks!
www.xeetstreetband.com
Intel 486 75Mhz - 16Mb RAM - Audiomedia III - Session Software
Old 08-21-2005, 03:54 PM
Taddy Taddy is offline
Default Re: Using 002R Mic Pre\'s with an outboard compressor..
I think you'll have to bring the signal to pro tools first via an aux channel and from there send it to your outboard compressor then back onto a pro tools audio channel.
Old 08-21-2005, 05:05 PM
Naagzh Naagzh is offline
Nope. You'll need an external mic pre.
You can perform a hardware insert after recording, but the quality of the signal may degrade due to the additional DA and AD conversions.
002R PT7.3.1
MacBook Pro 2.33
OS 10.4.8
Old 08-21-2005, 10:18 PM
The best reason to use a compressor while tracking is to control the peaks going into the A/D converter. That can't be done with the 002 or 002 Rack, since they don't have insert points between the preamps and the converters. This is an unfortunate reality.
The Mbox has inserts, but it's got its own issues.
Quad 2.5 G5, 4.5G RAM
Old 08-22-2005, 03:36 AM
A2D D2A A2D D2A is offline
Thanks!
Maybe a channel strip would have better served your purpose.
Old 08-26-2005, 11:33 AM
logancircle logancircle is offline
Can you do this using Digi 001 preamps? (I want to send both 001 pre's to an outboard stereo compressor before A/D). Do I set the outputs as like output 3/4, then bring them back in 1 & 2? SOrry, I'm a bit green. Thx.
Old 08-26-2005, 12:21 PM
jnash jnash is offline
Yeah, sorry, but the 001 preamps don't have a pre-A/D insert, either. It's going to mean more money, but your best option is probably to buy an outboard mic preamp--that will give you flexibility on patching in your compressor, and you'll upgrade the quality of your input stage as well. Or, if you're trying to keep the cost as low as possible, you might be able to swap your compressor for a similarly-priced channel strip that includes both a preamp and compressor--that would let you keep the compression pre-A/D as well.
James
[email protected]
Old 08-26-2005, 12:30 PM
Ducky Ducky is offline
How is the Digimax LT set up with their inserts?
Is this a good option for this configuration or are the LT inserts also a D/A conversion like the OO2?
Old 08-27-2005, 05:39 AM
The Digimax LT has proper inserts.
Old 08-27-2005, 12:36 PM
b mcgibney b mcgibney is offline
So does the octane
B
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers
How can I patch an outboard mono compressor into an 002R? tpthai2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-05-2007 04:35 AM
Lining outboard pre's through the Digirack pre's falsemetal666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-16-2006 04:53 PM
OUTBOARD Mic Pre's.... minor2nd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2004 02:33 AM
Routing - 002r mic pre's w/ ext. compressor Ignatius Reilly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-14-2004 03:00 PM
Outboard Pre's and Converters for 002... Booyah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-15-2003 07:42 PM
