Old 06-09-2004, 06:11 PM
dieseltracks dieseltracks is offline
Default Altiverb HTDM / RTAS Problems
Hello,
I keep having problems with my system when running Altiverb or most RTAS pluggins. I should have a fast enough system G5 dual 1.8ghz 512megs of RAM 200gig 7200rpm firewire 800 harddrive, HD3 Accel. The problem will occur with as little as 1 Altiverb pluggin instanciated and I will get the CPU to slow increase H/W buffer size (or some kind of message like that). I have the H/W buffer size set to 512 samples (which Altiverb recommends) the processor set to 99% (which will allocate 1 full processor to Pro Tools). I only have 512megs of RAM could that be the problem? Anyone having this problem too?
Thanks,
Chuck
Old 06-10-2004, 07:14 AM
soundeziner soundeziner is offline
Default Re: Altiverb HTDM / RTAS Problems
Increasing your RAM will make life in general better.
I've had two instatiations of Altiverb up on an HD1. While a great plug, it is one of the biggest resource hogs. They claim the new version requires half as much so that upgrade might help you immensely.
Todd A. Judge, MPSE
Altiverb... HTDM or RTAS? tlester Pro Tools TDM Systems (Mac) 1 08-15-2006 09:02 AM
RTAS or HTDM Altiverb? Jaylaca Pro Tools TDM Systems (Mac) 3 06-30-2005 03:28 AM
Altiverb RTAS or HTDM? picksail Pro Tools TDM Systems (Mac) 2 02-23-2004 09:48 AM
HTDM and RTAS MIDI timing problems Dustin Mosley Pro Tools TDM Systems (Mac) 1 11-20-2003 04:19 AM
Pro Tools 6.1 HTDM vs RTAS problems CraigLearmont Pro Tools TDM Systems (Mac) 6 10-01-2003 12:01 PM
