Old 01-27-2023, 02:56 AM
take77 take77 is offline
Default Re: How to use different timbre(articulation)in 1 track ?
Originally Posted by massivekerry View Post
It also depends on what (presumably) sample library you're using. Different devs have different methods for articulation switching if you can load multiple in one instrument. Sometimes it's MIDI notes (outside of the instrument range). Sometimes you can do it with Program Changes, which you can insert into a CC lane on the Instrument/MIDI track. Learn the instrument and you'll be a step closer.
+1 for VI's with key-switching features.
Or if you're using piano roll to trigger the VI you can enter notes on those designated keys at the points where you want the articulation to occur.
A rough sea makes a smooth sailor.
Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD
Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6
Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory
Old 01-27-2023, 11:41 AM
massivekerry's Avatar
massivekerry massivekerry is offline
I actually do not like key-switching as an articulation controller. If you decide to transpose an entire track or set of clips (change key for a singer's register or to make a transition smoother) you may forget (I have) that you had those key-switches in there, and suddenly everything plays back all cattywumpus. I try to re-map anything I can to use Program Changes, but some instruments stick with key switches. That's one thing I do like about the "Expression Map" idea - once you create the map, the instrument can still "use key switches" but that data is not presented in the Expression Map "CC lane" as such, so it won't be affected by any track/song transposition that you do.
Kerry Smith
http://apothekerry.com
Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro
Old 01-28-2023, 02:58 AM
I've yet to learn about Expression Maps but can see how that would be a more flexible option based on the reasons stated.
You guys are the business!!
Sibeliusの日本語サポートについて(技術的なご質問) Avid Audio Japan Admin Sibelius & Scorch フォーラム 0 07-06-2016 11:20 PM
Pro Tools 11 以降でショートカットが動作しない問題(Mac) Avid Audio Japan Admin Pro Tools (Non-HD, LE, M-Powered, Express) フォーラム 0 06-16-2016 04:08 AM
Pro Tools 11 以降でショートカットが動作しない問題(Mac) Avid Audio Japan Admin Pro Tools HD, HD Native、ICONフォーラム 0 06-16-2016 04:08 AM
TC electronic VSS3が発振(内部ループ)する soundista Pro Tools HD, HD Native、ICONフォーラム 0 08-04-2011 05:10 AM
互換性注意情報: Mac OS X Lion 対応状況(Pro Tools MP 9は未対応) Avid Audio Japan CS Pro Tools (Non-HD, LE, M-Powered, Express) フォーラム 0 07-20-2011 06:42 PM
