Pro Tools Carbon Shut Down
Merry Christmas all,
My Carbon has been fine and dandy for the past year, I woke up last week and the lights had all been shut down. The hardware will not turn on, I tried disconnecting and connecting the outlet as well as the Ethernet.
Take care brush your hair, Rey https://r-e-y.com/ macOS Ventura Pro Tools 2022 iMac (Retina 5K. 27-Inch, 2020) Processor 3.6 GHz 10-Core Intel Core i9 3.6 GHz Dual-Intel Core i7 16GB ram AMD Radeon Pro 5700 8GB Shure SM7B Mic Pro Tools | Carbon Komplete Kontrol M32 AKAI Mpk3 Mini KALI Lp 6 (2) |
Re: Pro Tools Carbon Shut Down
Are you sure you firmly pressed the power button and that both the power cable and power outlet are intact? Check with another piece of equipment just to be absolutely sure on this.
If it still does not power up at all I would contact the dealer you bought it from. Within the EU you should be covered by warranty within two years of purchase. |
I bought it a little over year ago from reverb.com
you might be out of luck then, it seems like you're in the US and warranty is only one year there.
but it seems that the Reverb seller is a company and not a private seller. I would definitely get in touch and if that won't work send it in for repairs to AVID. |
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? | pm mastering studio | Pro Tools | Carbon | 0 | 12-22-2022 01:54 AM |
Pro Tools 11.3.1 crashes on app shut down | martinaston | Pro Tools 11 | 0 | 02-27-2015 02:07 PM |
help!! pro tools le 7.3 shut down problems!! | dmt2828 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-07-2007 05:14 PM |
Pro Tools won't shut down!! | bigfrog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-06-2002 04:29 AM |
