Pro Tools 8 LE install HELP!
I've just downloaded Pro Tools 8. I am ready to install. However there is virtually zero guidance from the Digidesign site. Help!
So far the only guide I have read recommends cloning the mac hard drive as back up. Which I have done. There are 3 key questions I have below which have not been covered though. An idiots guide on the Digi site would be useful... I currently run Pro Tools LE 7.4.2 on a Mac Book Pro 2.5 Ghz Intel Core 2 Duo with 4 gb RAM, Mbox 2 Pro (firewire). Some basic questions: 1. Do I have to uninstall Pro Tools 7.4.2 before installing 8? Or can I install over the top? 2. Will my existing plug in's (from Pro Tools 7.4 and beyond) be in tact in Pro Tools 8? There is only BFD and one other plug in on the 3rd party content upgrade activation for PT 8. Why so little? Do I uninstall previous BFD to install the new PT8 LE BFD plug in version? 3. Do I have to get activation code for iLok for PT8 plug in's, there doesn't seem to be any supplied? Can anybody help. Any suggestions to the above questions much appreciated. Many thanks. |
Re: Pro Tools 8 LE install HELP!
1 - yes, uninstall any previous version
2 - Don't know, make a backup if no one else answers this question 3 - I didn't do any iLok actions for my stock PT8 plug-ins.
Mac Pro - 8 core 2.8 GHz - 6GB RAM - 10.5.8 Pro Tools LE 8.0 - MPT2 - 003R |
1. Agreed - always better to uninstall any previous version when upgrading.
2. The uninstaller will not remove the plug-ins, newer versions will be installed in place of the older ones, and any third-party plugs will remain intact. 3. iLok authorizations will be still active. You will only run into trouble if some plug-ins require a newer version to be compatible. HTH, C |
What version of OSX are you using??
Just a word of advice to save a possible headache. Make sure you go here to see if all of your 3rd party plugins are compatible with PT8. Tony
___________________________________________ Mac Pro 2010 2 x 2.66 / 40GB RAM / OSX 10.13.6 / PT2020.5 / Metric Halo ULN-8 |
OS is 10.5.6
Thanks for the comments so far. Much appreciated. |
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! | shamanrock | Windows | 13 | 12-27-2012 04:39 PM |
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions | b-pole | macOS | 2 | 08-31-2011 07:23 AM |
Can't install Pro Tools 8! Clean install, new system, Vista! | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 01-09-2011 11:16 AM |
Can't install Pro Tools LE - Insert disc but no option to install | Paul McConnell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-22-2010 08:13 AM |
Why install Pro-Tools to install drivers for Mbox2 | bigbobbysd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-23-2010 07:42 AM |
