  #21
Old 03-26-2021, 05:46 PM
paul_g's Avatar
paul_g paul_g is offline
Default Re: 2021.3 constant hangs
I recorded a 5 minute track on 128, then again on 64 and no hangs.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
  #22
Old 03-27-2021, 04:05 AM
Becharax's Avatar
Becharax Becharax is online now
well i am narrowing it down more ... if i go to 32 samples which is cool i won't have any hangs unless i record arm any audio track ....
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
  #23
Old 03-28-2021, 11:42 PM
Becharax's Avatar
Anyone has similar issues ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
  #24
Old 03-28-2021, 11:58 PM
JFreak's Avatar
JFreak JFreak is online now
Originally Posted by Southsidemusic View Post
a few soothe2 tracks
Made in Finland, great plug
Janne
  #25
Old 03-29-2021, 05:53 AM
JingleDjango JingleDjango is offline
Becharax this is an issue I've been dealing with since switching to my Apollo X8 a year and a half ago. Arming tracks will cause system hangs at 64 samples and below.
  #26
Old 03-29-2021, 06:03 AM
JFreak's Avatar
Self made problems guys. I very seldom have a reason to go below 128 buffer (@48k) which is/was the default playback buffer on HD systems. It is also typical latency of digital mixing boards used on stage. If that latency would be a problem, there would not be any live gigs mixed or monitored on digital consoles.
I even have great success using 256 buffer if needed. I have tested these latencies extensively for two decades already. 512 will be unusable for anyone, 256 is usable for most.
Though with modern systems it beats me why end user could just not have a slider of how many samples is needed. I would probably set it to 350 which is a real world DSP latency of typical full TDM mix, only TDM plugins included. And those ancient TDM systems were praised "fast".
Janne
  #27
Old 03-29-2021, 12:58 PM
off the wall's Avatar
off the wall off the wall is offline
I do large orchestral tracking and OD sessions at 128k buffer on HDX systems all the time. No complaints from the musicians about latency in the cues. Go to 256 though and you will have complaints or just people playing out of time.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
  #28
Old 03-29-2021, 11:48 PM
Becharax's Avatar
Well I never complained about 128 :) It runs smoothly for me and even with vocal tracking, Guitar Tracking I am absolutely fine ... it just beats me as to the point where I can go lower to 32 samples on Logic without a glitch and not being able to do so on Pro Tools no more no less :)
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
  #29
Old 03-30-2021, 11:54 AM
metalindian's Avatar
metalindian metalindian is offline
No freeze issue here, but some graphical glitch.
Inviato dal mio iPhone utilizzando Tapatalk
  #30
Old 04-01-2021, 10:54 AM
huzzam huzzam is offline
That's all well and good, but that doesn't change the fact that this is a regression. Whether or not you find it necessary or useful, the fact remains: On 2020.12, I can track at 64 samples with 99.5% stability (estimated, obviously). On the exact same system, 2021.3 freezes almost immediately, even when I'm NOT tracking.
I have rolled back to 2020.12 and again can track at 64 samples, 24/48 session. Recorded about 8 hours over the last two days, no hangs or freezes on 2020.12. (Also, 2020.11, 2020.5, 2020.3 worked well with these settings... It's worked well enough in the past that I'd "set it and forget it" when tracking, so latency just was never an issue.)
Literally nothing else has changed about my system. This indicates that something in 2021.3 has broken in comparison to 2020.12.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Any benefit to TDM in 2021? akopp Pro Tools TDM Systems (Mac) 41 01-12-2022 11:05 AM
PT 2021... Catalina? Or Big Sur? Eric Lambert Pro Tools 3 03-26-2021 12:41 PM
Come on! 2021 already. Just issue what’s right. DetroitT Pro Tools 2020 0 03-05-2021 05:35 PM
