moving clips
Hi.
Is it posible to move a clip by keyboard, to the upper or lower track by keyboard, not by dragging it with the mouse? I want to do it this way, to keep the TC/Sync. This way I can arrange the clips from 2-3 tracks on one track, and not moving left-right on the timeline (changing the timecode).
Florin Milian OS X 10.9 / Mac Pro Early 2009 / 12GB Ram / Protools HD 11 with HD Omni/Native Core. PC Intel Quad Core / Protools LE 8.0.3 / Digi Rack 003+ / Win7-64 |
Re: moving clips
select clip
x move edit selection down/up v or : Start(Ctrl)-drag with mouse (restrain movement to only vertical)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Re: moving clips
I don't understand... X ? V ? Best and fastest solution, many thanks...
Re: moving clips
Page 5 of the Pro Tools Shortcuts Guide V11.2 , Commands Keyboard Focus.
(Good to learn by hard, all on page 4 and 5)
Re: moving clips
ah, you mean cut and paste..
and the timecode? I use about 20 times that cut/paste per minute :))) cutting breaths ... I was searching for some shortcuts to move from track 2 to track 1 a clip (wave) without changing it's timecode (position in time) The second solution si much better and faster, thanks again. About the X and V, I thought it is some UP DOWN selected clip... not cmd+x and cmd+v. the cut paste method doesn't keep the tc, it can change it if it's done in a rush. Anyway, thank you again.
Re: moving clips
If you use the shortcuts for "move edit selection up/down" there is hardly a chance to screw that up and it will keep the TC.
Re: moving clips
moving all the clips! | TakenGrace | Pro Tools 11 | 6 | 06-21-2014 01:07 PM |
Moving MIDI clips causes them to consolidate | abt | Pro Tools 11 | 9 | 04-07-2014 09:07 PM |
PT11 loses automation when moving clips | Frank Kruse | Pro Tools 11 | 4 | 02-20-2014 12:54 PM |
Moving volume automation on separate clips | Goombot | Pro Tools 10 | 6 | 04-22-2013 11:18 AM |
Full scale volume when moving clips | Frank Kruse | Post - Surround - Video | 7 | 05-15-2008 03:49 AM |
