Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 08-12-2014, 04:06 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Pre record fader (aux) C/24
Hi. Thanks for the new discousion.
One way of many to do things with control surface, remote preamps for tracking.
(Template builds recommended)
With an Avid c/24 and remote controllable preamps I setup 24 pre-record-faders for riding record gain.
I course-gain-adjust at the preamps then route the analog preamps into aux input tracks that are bus assigned to record tracks.
This resembles a split-console..style for tracking.
1st bank of 24 for gain rideable faders with inserts for low latency plugs.
i.e. Pre record aux tracks.
2nd bank for monitoring, headphone sends and general reballancing for layoffs at the end of the session.
i.e. Post recording mixing
T.
Record fader malfunction Professor EL macOS 26 09-28-2011 12:29 PM
Master fader won't record automation when in "write" mode? JAZZ27 Pro Tools TDM Systems (Mac) 2 04-19-2008 07:23 AM
Deleted master fader, now can't record carlg1212 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-22-2007 02:06 PM
Mix It Like a Record "crashes" fader Naagzh Tips & Tricks 4 02-14-2007 08:33 AM
Using the Fader in Record mode brianpatrick General Discussion 8 04-01-2001 03:26 PM
