SCSI cable specs...
Can someone tell me how many pins are in the Digi 001 SCSI cable? I was just given an old Digi 001 that I would like to use at home but I have to buy an adapter cable to plug it into my G4 (as it does not have a SCSI port on the cpu). So I have to buy a cable that transforms the scsi into usb but I have no idea what type of SCSI cable the Digi 001 comes with. I just need the pin amount then i can order this cable...
Re: SCSI cable specs...
the 001 is not SCSI, it requires a host card inside your computer
the interconnect of the 001 and it's host card is rumored to be a standard 50 pin SCSI cable
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I guess I should have been specific, the 001 I have is a rack mount version and it does have a SCSI connector cable...hopefully you're right about the 50pin, thank you very much!
Tha cable that connects the 001 breakout box to the PCI card is a rare Micro D 68-pin SCSI cable. It's not a SCSI bus though. You need the 001 PCI card. The 001 PCI card is 5V PCI only, and will not work in any G5 or newer Mac.
Snake Cable Specs | Kenmillerjr | VENUE Live Sound Systems | 3 | 11-01-2011 06:17 AM |
Analog Patch Cable Specs | relaxo | Pro Tools TDM Systems (Mac) | 0 | 06-05-2003 12:36 AM |
Is cable for 24|Mix -> 882/20 standard SCSI-2 cable? | Last Legend | Pro Tools TDM Systems (Mac) | 2 | 01-18-2003 12:36 AM |
serial to 9pin cable specs | nemnemnem | Pro Tools TDM Systems (Mac) | 1 | 06-21-2000 08:36 PM |
Cable Specs | DJK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-11-2000 11:32 AM |
