Need a SCSI HD\" Cable for Session 8. ANyone Have?
Hi, inherited a Session 8 interface box and Powermac 8100 that came with just the software installed...no Master software discs (I don't know if i would need some authorization code
in case i need to reinstall - any idea? ) Mainly I want to buy a used or unwanted - cable that goes from soundcard to a SCSI (50-Pin Centronics) Hard Drive...required to run Session 8.. It was missing too. If anybody has either of these items (The cable Order # is CS600 - PT Project Card to SCSI 50 ---- ) Please drop me a line at: [email protected] Or, [email protected]. THANKS VERY MUCH! Mike
Voiceovers For All Media...Since 1970-something... |
Re: Need a SCSI HD\" Cable for Session 8. ANyone Ha
Sorry, we no longer sell the hard drive cable.
The Session 8 Mac software is not copy protected, and is still available online: http://www.digidesign.com/download/legacy/s8mac/
• linkedin •
Re: Need a SCSI HD\" Cable for Session 8. ANyone Have?
I had a PTIII system in a 9150 using an internal 50 pin scsi cable. Much better to use internal drives (the 8100 should have space to fit a couple of drives comfortably) and have everything power up with the mac instead of using external cases.
You have to be a little careful folding over the cable due to space limitations. But I never had a problem. I used cables that had terminators and had up to 3 drives on a single cable. I probably have a cable if you're determined to use external cases. email byronp at rogers.com You could also try http://www.oakbog.com/PT3NuBus.html for other software Find someone willing to part with PT version 4. That's best for a session 8. good luck, byron |
SCSI cable specs... | daimyojallday | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-07-2008 09:51 AM |
Digi001 scsi cable legnth | Symphonic4sound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-02-2005 11:43 PM |
Digi 001 cable - is it scsi? | chrispnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-24-2003 05:46 PM |
Is cable for 24|Mix -> 882/20 standard SCSI-2 cable? | Last Legend | Pro Tools TDM Systems (Mac) | 2 | 01-18-2003 12:36 AM |
SCSI Cable for ATTO? | johnnyd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-22-2000 08:36 PM |
