Old 01-13-2006, 01:10 PM
Jsswtpmp182 Jsswtpmp182 is offline
Default Edit Window Automation Question
Hey Everyone,
So I'm still new to Pro Tools, and I haven't been able to figure something out. When manually writing automation onto a track in the Edit Window, can I select all the points that I've made and move them all up or down while having them keep the same consistency between themselves? Like if I had one point on a volume automation track at -2db and another point at -4db, can I select the two, move them both down simultaneously -4db so that the one that was at -2db was now at -6db, and the one at -4db at -8db? I just believe there has got to be a more efficient way of moving every point up or down without manually having to go through and move them all individually. Thanks!
Old 01-13-2006, 01:11 PM
spkguitar's Avatar
Default Re: Edit Window Automation Question
Use the trimmer tool.
Old 01-13-2006, 01:17 PM
Hey Thanks a lot! I never would've guessed that and It's been driving me crazy. One more question, how can i select points and give them specific values by typing the value I want into somewhere?
Old 01-27-2006, 11:10 PM
Brain Digger Brain Digger is offline
What if you want to reduce the volume on a track but still maintain relative differences instead of absolute differences that are already set up in the automation??
XP Pro SP2
PTLE 7.4cs2-002R
Intel Core 2 Quad 2.4 GHz
K8V-SE Deluxe 4G DDR400
Radeon 9200SE-128M
Maxt 80G; WD 200G
CG8 200G SATA
Old 01-28-2006, 02:08 AM
Jenre Jenre is offline
I don't think there is a way to type in a specific value, I'm afraid. However, if you hold down control whilst you drag the select point you can adjust in very fine amounts.
Pro Tools 10.3 stopped displaying automation values in edit window mgoorevich Post - Surround - Video 17 12-28-2012 11:05 PM
mix/edit window question thruhiker Windows 2 11-19-2012 05:55 AM
Volume Automation - Edit Window stuseattle Pro Tools TDM Systems (Mac) 0 08-16-2010 01:58 PM
Lighten edit window and thicken the volume automation line Sukram Pro Tools TDM Systems (Mac) 26 12-09-2009 12:18 AM
edit window question travista00 Pro Tools TDM Systems (Mac) 1 08-22-2005 04:34 PM
