Old 11-10-2008, 06:57 PM
pguy pguy is offline
Default 8 Core Mac Pro users...
Hey Guy's....
How many processors have you selected in Pro Tools hardware setup?
I was told to select 4 processors.
Have your results varied greatly when choosing 4, 6, & 8 processors?
I don't have large sessions loaded into my Mac Pro yet, have not had time to transfer sessions from my PC.
Thanks.
Old 11-10-2008, 07:20 PM
@ndy's Avatar
@ndy @ndy is offline
Default Re: 8 Core Mac Pro users...
Yes, lots of different results and it depends on what I'm doing. When tracking, I use only 1 processor with a buffer set at 32 and it is solid. Then when I mix at higher buffers, I add a processor at a time as needed. I never use all 8. If I use VI's when I'm tracking, I set the buffer to 64 and use 2 processors. It is all variable depending on what plugins and VI's I use in a session. With experimentation you will find what fits your particular workflow.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Old 11-10-2008, 07:47 PM
Hey thanks Andy.
As a new Mac user, I really don't know anything about this at all.
Common sense i would think would tell you that the more the better, but, I guess that's not the case.
Old 11-10-2008, 07:48 PM
schuyler_c schuyler_c is offline
i'm set to use 7. works great, no hiccups, more power than i've ever needed. (i don't use many VIs, though.) YMMV.
- sky -
Mac Pro 2.8Ghz Octo, 4GB, 10.5.5, Digi002, LE 8.0
G5 1.8Ghz Dual, 2GB, 10.4.11, Digi003, LE 7.4
Originally Posted by daeron80 View Post
i used to think that mac was more stable but i've come to think that really it's just that, even when it crashes, mac is more fun.
Old 11-10-2008, 08:04 PM
@ndy's Avatar
I have high hopes for PTLE8! Hopefully we will be able to run lots of VI's and all 8 cores at a buffer setting of 32. Or maybe it will be possible when snow leopard comes out and we have to upgrade to PTLE8.1
Old 11-11-2008, 11:12 AM
DigiTechSupt's Avatar
You should only need to reduce the number of processors if you're using or have installed plug-ins that are not fully RTAS optimized - meaning they may still have some non realtime code in them.
Start with 8 processors and, if you see errors (6087 or 9128 being the most common), try reducing the number of processors by 1 until the errors go away. What this does is opens up a those processors for the non realtime code to run - you're still 'using' them, just not in a way that's apparent.
Avid Audio Tech Support
Support FAQ
Old 11-11-2008, 04:22 PM
@ndy's Avatar
I know digi can't officially name the "not fully RTAS optimized plugins", however it would nice to have a list so that we the consumers/users could put pressure on those companies who have not "optimized".
Old 11-11-2008, 07:33 PM
pasanta pasanta is offline
I keep mine set on 7. Using just PT I don't see any real difference now that everything I have is updated to current. But using Reason, I seem to have fewer hiccups and little hangs. I don't have any crashes at 8. it just seems a bit smoother set to 7 when running Reason along with larger PT sessions (I have the DV Toolkit and also run Ivory and NI B4 a lot). FWIW, anything 7 and under feels smoother.
Old 11-12-2008, 04:04 AM
johnnyz johnnyz is offline
i am also on a macpro 2.8 10 gigs of ram 10.5.5 protools m-powered 7.4.2 and i have been getting the 6101 error message,telling me to increase the buffer,last nite i was playing bask like 3 tracks and had my buffer set at 256 and processors set to 8,i am also using cubase ai4 with a yamaha n-12 and it is rock solid,on the protool side i am using a m-audio profire lightbridge hooked up to a yamaha 01v96 v2 ,Is it the software? the interface? I am stuckShould i upgrade to protools le?Any help is greatly appreciated,johnny z.
Old 11-12-2008, 10:30 AM
And what happens when you set the number of processors to 7?
Support FAQ
Core Audio for HD users still utterly crippled Vinylizor Pro Tools 9 17 12-08-2010 02:19 PM
Any iMac Core 2 users yet? MarkusB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 08-27-2008 07:17 AM
8 Core Users?? bbob Pro Tools TDM Systems (Mac) 17 09-13-2007 08:41 AM
Any Core 2 Duo users yet? tjkili 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-10-2006 08:03 AM
Interesting Question for Core Duo Users... Rock_Artist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-15-2006 01:34 PM
