Old 12-03-2009, 04:36 PM
tonicjeff tonicjeff is offline
Default Nudge By Frames Not Working Right
Time code set to 29.97
Nudge set to frames
Grid is set to Frames
Set to Slip
Grab a midi note to nudge by frames.. It skips frames... this is random.. sometimes it happens sometimes not.. If I press and hold the nudge so it goes back behind where I want it and then go back it seems to work.. Bug?
Intel Nehalem 8 Core 2.26 w/10 gigs of Ram
4 internal sata drives (1 terabyte)
Magma Pci to PCIe 6 slot chassis
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Old 12-04-2009, 02:23 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Nudge By Frames Not Working Right
Originally Posted by tonicjeff View Post
Set to Slip
Well it won't move frame by frame when in slip mode! it will be free moving. it needs to be in grid mode or relative grid mode
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-04-2009, 04:13 PM
Thanks.. Tried it that way too with the same effect.. sometimes it will just skip frames.. 3 at a time or so.. nudge is set to frames.. grid is set to frames.. only when holding a midi note.. trying to get the midi not right onto a cut.. Thanks for any other help..
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Old 12-05-2009, 03:49 AM
studiostuff studiostuff is offline
29.97 drop frame...?
Old 12-05-2009, 07:19 AM
29.97 non drop.
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Pro Tools to Final Cut Pro (Working in 60 Frames) vinlance Post - Surround - Video 14 05-16-2013 11:00 AM
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? EricHirsch ICON & C|24 1 08-13-2009 08:07 AM
BUG?: Selecting Frames in Grid Mode Not Working i hear dead people Pro Tools TDM Systems (Mac) 4 02-27-2007 05:15 PM
Nudge by 10 Frames Gone? Rick Sanchez Post - Surround - Video 9 12-05-2005 10:14 PM
Stationary Playhead and Video Frames display - Working Well for Anyone out there? PTPerson Pro Tools TDM Systems (Mac) 1 07-21-2000 04:40 PM
