AAX / AAX DSP insert order
Hello,
Does the rule of having RTAS first then TDM still applies with AAX / AAX DSP plugins ? Thank you. |
Re: AAX / AAX DSP insert order
I believe it does, though the hit on your voice count is only 1 voice per channel and not 2 voices. When you go TDM-->RTAS-->TDM on a mono signal path, you lose 2 voices going into RTAS and 2 voices coming out of RTAS. With HDX, you only lose 1 voice going into Native and 1 voice coming out of Native.
so also the same with latency I presume ?
on old RTAS/TDM system, it also resulted in significant latency increase. |
Twice the buffer I presume as it has to leave the card and come back. So if your computer is powerful enough, you can minimize this by setting the buffer as low as possible.
Can't beat the laws of physics. It is either CPU or DSP who processes the signal, and if you switch between the platforms you will have latency issues sooner or later.
ProTools HD10 with HDX-2. audio tracks only. |
The problem is, it takes CPU cycles to bring the audio into and out of DSP so if you have lots of traffic between DSP and CPU, eventually there is going to be a CPU spike that stops recording or playback
And it's usually best to use only DSP plug-ins on record enabled tracks.
Plug-In Insert Order | guatamas | Pro Tools 10 | 3 | 03-16-2013 04:50 AM |
Order region list in the order the regions are on a track | Wesselink | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-30-2009 06:53 PM |
Insert order for vocal plugs? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-30-2007 04:13 PM |
insert plugin order | 4times4mil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-13-2006 03:22 PM |
How to insert time / insert measures, without upsetting tempo map and markers | imp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2003 05:45 PM |
