Plug-In Insert Order
Does placing a plug-in(s) on any insert have an affect on the signal? I know the order of plugins does make a difference (e.g.) comp-eq or eq-comp. I see some engineers start their insert processing chain at insert b or c instead of a. Does this actually do something?
Nope a b c don't matter they are series but where u start don't matter
I usually go b first that way I can put something else first should the situation arise
Re: Plug-In Insert Order
yes - it's a convenience thing. Ever since having 10 inserts per channel I leave A open. It prevents from dragging pluggin's down just to insert something in front of them for example.
I used to typically insert the gain / phase plugin on A as well (although inout gain and phase control are these days handles by the channelstrip plugin more often then not) Anyways - sound or signal are not affected by leaving inserts empty. Chris
Chris Lambrechts Applications Specialist- Live Sound |
Thanks for the responses, I thought it wouldn't, just wanted justification.
AAX / AAX DSP insert order | sinewavz | AAX Plug-ins | 7 | 04-14-2016 11:44 PM |
Insert order for vocal plugs? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-30-2007 04:13 PM |
insert plugin order | 4times4mil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-13-2006 03:22 PM |
What order should plug-ins go in? | George Siede | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-11-2005 11:13 AM |
What`s best order of plug ins | jeffinmarin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-02-2001 09:39 AM |
