Quick Question - Easy Answer...
Completly drawing a blank here
How do you go from starting up a session at a certain BPM - Then changing the BPM at say the chorus and then using the original BPM while continuing on with the session - Scenario: * Verse #1 BPM = 137.00 (8 Bars) then switch to the Chorus #1 BPM = 96.00 (4 Bars) * Repeat Verse #1 and Chorus #1 Thanks in advance... |
Re: Quick Question - Easy Answer...
Ok, turn on the conductor (transport, little dude with a baton.) Right click (or control click maybe) on the little bar that has a tempo in it. 120 is the default. You can add as many tempo markers as you have tempo changes to the bar at the top. This will only affect midi and grid locations though, it won't stretch the audio to fit the new time divisions.
-Olaf |
Sorry - Unfortunately that's changing the whole sessions BPM Grids now - I am trying to create a Verse BPM then switch to a Chorus BPM within a song (2 Different BPM's in a session) -
First change all your markers from Bars and Beats to Absolute (wish their was a global command for this, but there isn't).. then from the top of the song to the end work your way down and enter tempo changes with the MIDI menu. There's no way to do a accelerando or ritard, it'll be a quick tempo change unless you manually do small tempo changes.
You can also import a tempo map via a Standard MIDI File from another program.. which sometimes is easier. Rail
"First change all your markers from Bars and Beats to Absolute (wish their was a global command for this, but there isn't).. "
Rail - I knew you'd come to the rescue - I don't think I am doing this right - Having trouble getting into "absolute" (It's already in that mode in the grid option and right clicking the bars beats) - Is thar right? Will you be able to bullet the steps on how I should go about this (Pretty new to tempo changing within a song) - Also will these tempo changes show and lock at specific parts within the song? |
Open the Marker window (Ctrl+5). Click on a Marker then double click it to edit it.. in the Marker dialog mae sure the Reference is Absolute - usually the default is bars and Beats. Click OK. Do the same for each Marker.
Rail
Rail - Ctrl+5 brings up the speaker icon - I think the preferences need to be changed to what your system is at...
5 on the numeric keypad with Num Lock enabled - which is the mode it should be in while running Pro Tools.
Rail
Tried it with num lock on still turning cursor into speaker icon - How do i do this manually - Also my original tracks that were locked into a certain BPM have moved with all the adjustments Ive tried so far - Can I reset this as well, so I don't lose what I've created - Wow all this Just to create 2 seperate BPM's in grid mode within my session...
Control+5 on the numeric keypad with Num Lock enabled has to bring up your Markers Window.. but you can also open it via the Windows Menu in Pro Tools.
The Numeric Keypad is that thing on the right of your main keyboard with all the numbers that looks like a calculator To get your session bak to where it was - either revert to your saved session (you did save before messing with the tempo).. or delete the tempo events you added and reset the tempo to your original tempo. To delete tempo events: You can either drag across the tempo events in the tempo timeline and hit Backspace, or you can Alt+click on each tempo event. Rail
Stupid Question, Assumed Easy Answer. | HDK_Ent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-21-2010 02:16 PM |
easy question, playback- need an answer asap!! | jayme | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-14-2007 04:29 PM |
quick question needs quick answer | SublimeAndy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-27-2005 09:44 AM |
Stupid Question - Easy Answer | jordan23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-13-2004 10:09 AM |
just read this cause i know some one can answer this question easy thanks | Cali Hendrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-24-2003 01:00 PM |
