Old 01-11-2002, 06:58 PM
DarkShade DarkShade is offline
Default digi error
Greetings,
Alright, DAE memory low....
Has anyone had this problem before?
Everytime I start up I get this message and then it shuts down. I've tried to run the digi test and it crashes.
Any ideas' [img]images/icons/confused.gif[/img]
Old 01-11-2002, 11:23 PM
Jorge442 Jorge442 is offline
Default Re: digi error
how much memory do you have installed?
maybe if you´d post more info about your system.....
what a long, strange trip it´s been
www.abacomusic.com
Old 01-12-2002, 12:52 AM
geminymusic geminymusic is offline
hi,
change the location of your disk in the programm in section "settings harware".
take harddisk with more space...
Thomas
Hamburg / Germany
mailto:[email protected]
Old 01-12-2002, 08:58 AM
Reji Reji is offline
DarkShade,
Pull out your digi PCI card from the slot and fix it correctly. You must hear a click sound after you insert the card firmly. I had the same problem when I did first time.
Regards,
Reji. [img]images/icons/tongue.gif[/img]
Reji/..
Old 01-17-2002, 11:55 AM
grendel grendel is offline
Did you change your hard drive to DMA
Old 01-17-2002, 01:41 PM
Bastiaan Bastiaan is offline
did you just install the 001?
what's the amount of ram installed?
did you change anything with your setup?
do you have problems in other programs?
do you run other programs?
did you check the minimum ram for ptle?
we need to know stuff like this. Otherwise its like going to the doctor and saying "it hurts" without telling where.....
Bastiaan
What's that?
- That's the machine that goes "pling".
Bastiaan
Digi 001 Error bigtunes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-27-2003 12:44 AM
Digi 001 Error pxpx83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-02-2002 04:52 AM
Digi 001 - Logic Audio - (Error -6031) and the error (-10011) - Direct I/O booyaaslam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-04-2002 01:55 AM
digi 001 error daeron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-13-2002 02:05 AM
Never have seen this error before, Digi, anyone, please help! Mt.Everest Pro Tools TDM Systems (Mac) 6 08-26-2001 11:38 AM
