Old 07-17-2021, 01:07 PM
goshalev goshalev is offline
Default Re: GUI freezes frequently after Update
Same problem
No wifi no internet
Old 08-03-2021, 07:06 PM
scottkchurch scottkchurch is offline
Default Re: GUI freezes frequently with 2021.6 on M1 Mac
+1
PT Carbon, iMac M1, MacOS 11.5.1
Old 08-03-2021, 08:19 PM
JFreak's Avatar
JFreak JFreak is offline
I don't see it here. Fully loaded M1 Mac Mini with clean install of Big Sur 11.5.1 and PT 2021.6
Janne
Old 08-03-2021, 09:40 PM
Teej Teej is offline
Have you experienced the beachball at all with .6 or is this your first install? If .6 is running smoothly on M1 after all, it's a killer release.
Will try clean install of 11.5.1 + 2021.6 when I have some downtime, currently with 11.2.3, 2021.3.1 is the better option for me.
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1
Old 08-03-2021, 09:43 PM
JFreak's Avatar
No beachballs here so far, but only one week worth of testing. Let me repeat myself, this is a clean install, not factory install.
Janne
  #16
Old 08-04-2021, 01:04 AM
Roger, thanks for clarity...will try it out.
  #17
Old 08-04-2021, 11:25 AM
audiogamble audiogamble is offline
Can you describe a bit more about your setup? Are you using many 3rd party plugins? If so, which ones are you using most often?
Are you mixing? Producing? Recording?
Are the tests you're running controlled / benchmark style tests, or are using this system in a daily work environment ?
  #18
Old 08-04-2021, 11:38 AM
JFreak's Avatar
So far this is testing with recording silence, but once I gain confidence will be for real. My sessions are mostly mixing, with only max half a dozen VI's -- and for that this 16GB memory limit seems to be just enough.
Only a week worth of testing so too early to say. But looks promising. Every 3rd party plugin you can think of basically. Only few bad ones found so far, most notoriously Sonnox Pro Codec which does not work as AAX, AU or Standalone.
Janne
  #19
Old 08-04-2021, 08:59 PM
Just to be clear before I wipe this mac mini and start from scratch, you have tried more than just the silence recording test right? You've done some mixing with 3rd party plugs and had no beach-balling?
  #20
Old 08-04-2021, 09:08 PM
JFreak's Avatar
Yes I have, but nothing serious. Only testing myself so far, nobody else coming to a session. No beachballing so far, most serious issue being Sonnox Pro Codec does not work.
Janne
Protools 2021.3.1 slow to load and then freezes BarefootWarrior Pro Tools 0 04-22-2021 08:59 AM
2021.3 Installation Freezes Computer gregklau Pro Tools 5 04-04-2021 10:06 AM
New laptop-windows freezes when starting a session on win7 64 reltucdc Pro Tools M-Powered (Win) 0 10-28-2010 09:55 AM
Computer freezes when starting new session Archie Gates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-27-2000 12:09 AM
