Can VCA Master be used as automation Trim in "vanilla"?
Latest reference manual I found is marked 12.1, so not sure what is HD and not.
(no install yet, I wait for an iLok to arrive) It states automation Trim is HD only - true/false? But figured, you can just use VCA master to do the same thing, or? Even just assign, adjust VCA fader, and then unassign again - it would change all automation for a track in a relative way? I guess with Trim, possible sends will be standard and not adjusted as with VCA. Thanks. |
Re: Can VCA Master be used as automation Trim in "vanilla"?
What is the goal here? If its to do an overall adjustment to a track that has automation in place, there are several ways to accomplish this.
#1-Adjust the output of the last plugin on the track #2-add the TRIM plugin after the last inserted plugin and adjust #3-advance past the last breakpoint(showing the VOLUME line) and drag the line up/down Given that the latest update to 12 gives VCA's to everyone, yes, that can work too, but seems like the "long way 'round" to me
Why complicate things - a trim of last inserts do exactly what I want. Only time to use VCA I can think of then would be if to export using OMF/AAF - getting automation with it. Plugins are lost. |
Trim tool requires breakpoint on clip boundary for "automation follows edit" to work | simonchase | Pro Tools 11 | 5 | 07-29-2014 06:41 AM |
"Compiling" multiple sessions into one "Master" session. Any pointers? | Nollykin | Tips & Tricks | 17 | 12-09-2013 10:36 AM |
Feature Request: "Trim" as Automation Mode | Dabeed | Tips & Tricks | 17 | 01-18-2010 03:14 AM |
