Closed Thread
  #31
Old 05-21-2014, 08:50 AM
mesaone mesaone is offline
Default Re: Pro Tools 11 Crash Reporter - send in those crash logs!
If I recall correctly, Pro Tools 11 won't import OMF or AAF files with embedded video.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
  #32
Old 05-21-2014, 12:48 PM
Marcel Risberg's Avatar
Marcel Risberg Marcel Risberg is offline
Avid,
Do you still check the crash reports coming in? ;-)
I've recently purchased and upgraded to Pro Tools 11. 11 crashes an awful lot on me, a few times an hour actually. I keep sending those crash reports to you as often I can but sometimes 11 just hangs and I have to "Force Quit". When that happens, Apple gets the report instead. These crashes most often happen when I close Pro Tools or when I close a project (SHIFT-CMD-W).
EDIT: 11 does not crash on me that often anymore since I began running it under 10.9.3 instead of 10.8.5 (both being completely fresh installs).
Best regards,
//Marcel
Marcel Risberg
Production sound and audio post - ljuddesign.se
Enthusiastically sharing knowledge and experience at Stockholm Film School.
🛠 Pro Tools Ultimate 2019.10 · HD Native · HD Omni
🎚 EuControl x.x.x · Artist Control · Mix · Control App
🦑 MacPro5,1 · 12C24T @3.46GHz · 48GB · SSDs · macOS 10.13.6 (17G5019)
📺 Separate video playback machine
🥇 Covered by ZDT/TLC · Keeping DAW OS clutter free
  #33
Old 07-29-2014, 01:29 PM
Audioartist Audioartist is offline
Default Re: Interesting crash behavior
Originally Posted by Peter Baird View Post
Since I began Arsenio back in September I've been keeping the session files on one of the data drives. I'll finish a show, do a save as, rename the session to the current show number, wipe the audio and the automation, and do the next show. No crashes, no drama at all.
My normally brick-solid 11 HDX system had an interesting quirk last weekend. I had moved the truck to cover another job, and during setup I did what I used to do as standard procedure in TDM: I built the session on my system drive, and pointed the session to record to the data drives. Pro Tools then started crashing, crashed all morning, and had me very concerned.
Thinking that it couldn't possibly be that simple I closed the session, moved it to a data drive, re-opened it, and never had another crash (another day and a half of work).
It's possible I'm conflating different causes and effects here, and that the two things aren't related. I merely offer this as yet another piece of the puzzle. I'm going to RTFM tonight and see if I can find what Avid says about this.
Peter
I am a little interested in "standard procedure in TDM: I built the session on my system drive, and pointed the session to record to the data drives."
Is that something that is important in TDM sessions for some reason?
Why not build the session on the drive you are recording to?
Thanks!
Patrik
  #34
Old 07-31-2014, 10:21 PM
trin trin is offline
I'm running PT 11.1.2 on my iMac, OS10.9.4 with UAD Apollo quad.
PT 11 started off well, but lately I notice weird crashes. No freeze, no warning. ProTools just 'Poof'.. disappears of the screen. I've been sending reports. It would probably happen at least once a day... I don't know what else to do. I get nervous every time I start working on ProTools these days..
Any suggestion or does anyone have this issue?
Using mostly Native instruments Kontakt, Nexus2, Spectrasonic inst and UAD plugins...
  #35
Old 07-31-2014, 10:23 PM
JFreak's Avatar
JFreak JFreak is online now
10.9.4 is not supported yet, but hopefully there will soon be a 11.2.1 which should work better with the current OSX
Janne
  #36
Old 07-31-2014, 10:42 PM
Thanks.. I really hope they come up with the update soon. I didn't see on the website where there was a compatibility issue...
So far that has been the only problem with PT 11. Once that's fixed, it might be one of the most solid version of PT I've worked with since PT 7!
  #37
Old 01-18-2015, 06:07 AM
Fuzzyc Fuzzyc is offline
I just upgraded to PT 11.3. When I tried to turn off elastic audio on a specific track I get the following error.
Assertion in "e:\ code\ 148029\ protools\ newfilelibs\ time\ Time_TypedBase.h", line 164.
When this happened it wipe out all audio data on that track and the only way to get rid of the error message was to close out the session. Thank goodness for auto-save!
Model: PC AudioLabs Rok Box i9
OS: Windows 10 64 Bit
CPU: Intel(R) Core(TM) i9-9900KF CPU @ 3.60GHz
Memory: 32GB
Internal Hard Drives:
500GB= Programs
1TBGB= Audio
1tbGB= Samples/Back Up
External Hard Drives: Verbatim 1TB USB Drive
RME Fireface UFX Interface/Preamps
Pro Tools 2023
Focal CMS 65 Monitors
Avantones
  #38
Old 01-29-2015, 12:37 PM
mfhorn63 mfhorn63 is offline
I run 11.3 on multiple machines, at school and at home, and get numerous crash and error messages.
Crash reporter causes hang on all machines.
School machines:
Error occurs when trying to enable or use any plugins. We have nothing but the bare bones basic install plugins.
See the attached jpg for screenshot.
"AAE error 6"
Also, trying to open the demo session from Avid, as well as sessions from our old PT SE install causes PT 11 to hang (not responding).
Dell Optiplex 3020
Hardware Information
CPU Intel(R) Core(TM) i3-4150 CPU @ 3.50GHz (4 Cores)
Current Processor Speed 3500MHz
Graphics Card Intel(R) HD Graphics 4400 - 57MB Free Video RAM, 64MB Total
System Manufacturer Dell Inc.
System Product Name OptiPlex 3020
System Serial Number GP4RP22
System GUID 4c4c4544-34100050-c0c75280-3232504f
Processor Voltage 2.09
External Clock Speed 100MHz
Power Supply AC Power
Operating System
OS Windows 7 Service Pack 1 (Build 7601) 64bit (Language: 1033)
OS Install Date Tue 2014-12-23 13:21
Screen Resolution 1680 x 1050 (32 bpp)
Browser IE 9.11.9600.17420
Hostname AM153-01DV
DNS Server 158.142.16.36
External IP Address 158.142.113.13
System Directory C:\Windows\system32
Common AppData Directory C:\ProgramData
System Boot Drive Device \\.\PhysicalDrive0
UAC Status Enabled
Memory Devices
Number of Used Memory Devices 1
DIMM2 on SysBank 4096 MB, 1600 MHz (Form Factor: DIMM, Manufacturer ID: Samsung, Serial Number: 0DC0290690E1, Part Number: M378B5173DB0-CK0 )
OS accessible physical memory 4014 MB
Commit limit 8027 MB
Total virtual memory 2047 MB
Hope someone can help!
Closed Thread
Pro Tools LogFiles? .dlog (pro tools crash logs!?!?) crizdee Pro Tools TDM Systems (Mac) 1 03-23-2014 08:06 AM
H E L P !! Crash Logs Here ----->>>>>>>> RBp Digidesign Hardware & Software 0 11-23-2010 05:37 PM
Crash Logs pherzfeld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-21-2008 02:49 PM
Where to send crash logs? studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-11-2007 04:38 PM
Crash logs Stig Eliassen Pro Tools TDM Systems (Mac) 2 03-07-2005 05:06 AM
