Old 12-02-2011, 01:20 PM
Lilblood904 Lilblood904 is offline
Smile Music production setup
Hey I'm new to forms sry if I posted in wrong area. My question is this. I'm trying to build a new comp for producing music beats n etc going all out and use the comp for recording and all. Should I use a comp based on the i7 2600k or use the new sb e set up? I kno production reqs alot of CPU n ram power. So would I c a big diff going i73930k or the 4core CPU vs getting a 2600k? X79 = 4 channel ram with up to 8 slots vs duel channel ram with the z68.
Old 12-03-2011, 04:33 AM
Ant B Ant B is offline
Default Re: Music production setup
I don't think it's going to make a huge difference. I use an i5 2500 and 6GB ram and haven't hit a wall yet..I don't do huge orchestral compositions either, though - but I do some pretty plugin/vi/track heavy mixes
Old 12-03-2011, 11:38 AM
Rly? I thought kuzz music takes alot of ram power that the quad channel ram would make it 50% better? The old gen uses dual channel ram so quad is dibble that.
Old 12-03-2011, 02:34 PM
I mean it could make a difference but honestly I have stock ram ..stock everything except my hard drives and I have no issues. One area where it might make a huge difference is with that new playback from ram or whatever feature if you have HD or the toolkit and 10
Old 12-03-2011, 09:06 PM
Would love to see a Sandra report on your i5, and some notes on your BIOS settings. I can't get good performance out of mine, which is i5 2500K(not overclocked), Asus P8P67, 8GB of Kingston DDR3 1600 and either a GeForce 210 or ATI 5480 graphics card(with either Windows generic driver, or latest from each company)
Old 12-05-2011, 04:35 AM
Sure I'll try to remember when I get home - but I literally only customized the hardware specs on HP.com, added an internal a usb external for data storage and did the tweaks avid/digi recommends for win7 systems and that's it. I haven't changed anything in the bios, added special performance memory or anything like that and the vid card is a cheap nvidia ?400 that barely runs bf3 smoothly in 640 lol
Old 12-05-2011, 12:27 PM
SiSoftware Sandra
Computer
Model : HPE-510t
Workgroup : SOUNDLAB
Host Name : i5
User : Anthony
Processor
Model : Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
Speed : 3.49GHz
Cores per Processor : 4 Unit(s)
Type : Quad-Core
L1D (1st Level) Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 (2nd Level) Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 (3rd Level) Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing
Computer
Mainboard : Pegatron 2AB6
BIOS : AMI (OEM) 7.13 05/04/2011
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 6GB DIMM DDR3
Chipset
Model : HP Core (Sandy Bridge) DRAM Controller
Front Side Bus Speed : 100MHz
Channels : 2
Memory Bus Speed : 2x 667MHz (1.33GHz)
Memory Module(s)
Memory Module : Samsung M378B5773CH0-CH9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : NVIDIA GeForce 405 (16 SM4.1 1.4GHz, 1GB DDR3 1.58GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce 405 (16SP 2C 1.4GHz, 1GB DDR3 1.58GHz 128-bit)
Compute Shader Processor : NVIDIA GeForce 405 (16SP 1.4GHz, 1GB DDR3 1.58GHz 128-bit)
CUDA GP Processor : NVIDIA GeForce 405 (16SP 2C 1.4GHz, 1GB DDR3 1.58GHz 128-bit)
Storage Devices
Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm) : 932GB (C:) (D:) (Q:)
Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (E:)
WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (O:) (P:)
WDC WD10TMVW-11ZSMS0 (1TB, USB3/SATA300, 5200rpm, 8MB Cache) : 931GB (N:)
WDC WD5000BMVV-11GNWS0 (499.4GB, USB2/SATA300, 2.5", 5400rpm, 8MB Cache) : 465GB (L:)
Generic-SD/MMC (USB2) : N/A (G:)
Generic-Compact Flash (USB2) : N/A (H:)
Generic-SM/xD-Picture (USB2) : N/A (I:)
Generic-MS/MS-Pro (USB2) : N/A (J:)
hp CDDVDW TS-H653T (2GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 2GB (F:)
WD Virtual CD 0730 (31.5MB, USB3) : 30MB (M:)
WD Virtual CD 070A (700.4MB, USB2) : 668MB (K:)
Logical Storage Devices
SYSTEM : 100MB (NTFS)
Protools (E:) : 466GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache)
Samples (O:) : 432GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
MainBack (N:) : 931GB (NTFS) @ WDC WD10TMVW-11ZSMS0 (1TB, USB3/SATA300, 5200rpm, 8MB Cache)
PTBack (L:) : 465GB (NTFS) @ WDC WD5000BMVV-11GNWS0 (499.4GB, USB2/SATA300, 2.5", 5400rpm, 8MB Cache)
Media (Q:) : 440GB (NTFS) @ Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm)
System (C:) : 479GB (NTFS) @ Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm)
RECOVERY (D:) : 13GB (NTFS) @ Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm)
Video Edit (P:) : 500GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm)
Removable Drive (G:) : N/A @ Generic-SD/MMC (USB2)
Removable Drive (H:) : N/A @ Generic-Compact Flash (USB2)
Removable Drive (I:) : N/A @ Generic-SM/xD-Picture (USB2)
Removable Drive (J:) : N/A @ Generic-MS/MS-Pro (USB2)
My DVD (F:) : 2GB (UDF) @ hp CDDVDW TS-H653T (2GB, SATA150, DVD+-RW, CD-RW, 2MB Cache)
WD Unlocker (M:) : 24MB (UDF) @ WD Virtual CD 0730 (31.5MB, USB3)
WD SmartWare (K:) : 615MB (UDF) @ WD Virtual CD 070A (700.4MB, USB2)
Peripherals
LPC Hub Controller 1 : HP H67 LPC Controller
LPC Legacy Controller 1 : Fintek F71858DG
Audio Device : HP Cougar Point High Definition Audio Controller
Audio Codec : Integrated Device Tech 76C7h
Audio Device : 6922 High Definition Audio Controller
Audio Codec : nVidia 000Bh
Disk Controller : HP Cougar Point 6 port SATA AHCI Controller
USB Controller 1 : HP Cougar Point USB Enhanced Host Controller #2
USB Controller 2 : HP Cougar Point USB Enhanced Host Controller #1
USB Controller 3 : 7003 Renesas Electronics USB 3.0 Host Controller
FireWire/1394 Controller 1 : VIA VT6315 Series Firewire Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.2
Old 12-05-2011, 12:49 PM
Regarding the Sandra, what are these 2 drives doing?
both are too slow for recording with good performance(but are fine for backups and archives). Also, what interface are you using? My i5/Asus setup also has a VIA firewire and it doesn't work at all with Pro Tools9 and my 003(added a Siig card with a TI chipset and that runs fine). Have you tried the Dverb2 test yet? Curious on your numbers(see the first page of the i7 thread for details on the test). Its really a basic system check and gives you a benchmark that you can compare over time to see if your system performance remains consistent.
Old 12-05-2011, 12:52 PM
Dism Dism is offline
Well both have the name "back" in their titles, so I'll assume they are backup drives.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 12-05-2011, 12:58 PM
Yeah both backups and using a profire 2626 - never tried the dverb test - not going to be shattering any boundaries with a stock i5 lol
Music Production set up Druanon Getting Started 12 06-17-2013 01:06 PM
Music production took kit 2 DaNOC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-14-2010 04:52 PM
Music Production Kit Micah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-18-2008 09:28 AM
Music Production DDM Tips & Tricks 1 02-04-2005 12:05 PM
where can i buy Pt 5.1 for Music Production vudoo Pro Tools TDM Systems (Mac) 9 07-25-2002 08:23 AM
