Old 11-09-2011, 05:04 PM
dts350z dts350z is offline
Default System Usage Window not as described
On page 81 of the pro tools 10 reference guide it talks about the Cache Meters in the System usage window.
"Cache Meters
(Pro Tools HD and Pro Tools with Complete
Production Toolkit
Only)"
So I have CPTK2 (and I'm mixing in surround) but I don't see the cache meters?
Is there some new version of CPTK2 I need? Do I need to re-install it after un-installing Protools 9 and installing PT10? I was all ready to install it when I noticed I already had surround, and still had the plugins that came with CPTK2, so I figgured I was all set.
Old 11-09-2011, 05:07 PM
Drew Mazurek's Avatar
Default Re: System Usage Window not as described
You have to select something other than "Normal" in the pulldown so PT knows to allocate that RAM for caching, then they should show up.
www.drewmazurek.com
Help with System Usage Window!! Drummersound Pro Tools TDM Systems (Mac) 4 09-12-2011 08:48 AM
System Usage Window zlr77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-09-2011 09:54 AM
System Usage window. maccool Tips & Tricks 2 04-16-2005 01:37 PM
system bar in sys usage window hobo123455 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-01-2004 02:21 PM
system usage window?? carbomb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-03-2002 07:54 AM
