Old 02-11-2006, 08:08 AM
madoneman madoneman is offline
Default amplitube.. can\'t find it in my plugin\'s
hey guys..
ok, so i loaded amplitube on my daw and for some reason i can't seem to find the plugin on my plugin options. i checked to see where the plugin installed, but i am not sure what folder it needs to be in so that i can access it via my plugins menu. i am thinking that i may need to move the files to a different location? where should they be moved to, what folder do they need to be in for them to work?
simple quesion, i know..
gracias!!
Old 02-11-2006, 08:16 AM
spkguitar's Avatar
Default Re: amplitube.. can\'t find it in my plugin\'s
The IKMultimedia installer should have put them in the proper location, unless you changed the location during install, or you have a non-standard Pro Tools install (not at all recommended).
What version of Amplitube?
Old 02-11-2006, 08:33 AM
i have the bundled sampletank/amplitube plugin that came with my 002, when they first came out. the i will try to install from scratch again, however i don't remember changing the location at the time of installation. and.. my ptle is standard install... this is the only time i have had this situation come up. what folder should these 2 guys be in?
Old 02-11-2006, 08:39 AM
spkguitar's Avatar
Ahhh, The original Amplitube LE?
There is actually an update for that on the IKMultimedia website. Go to Support->"Access the User area here" then "Download software updates and free contents" to get the latest version. It should install into the proper place, and it fixes a TON of bugs that were in the original.
Old 02-11-2006, 08:58 AM
ok.. so i will install amplitube, then install the update.. reboot and it should be good to go?
Old 02-11-2006, 09:02 AM
spkguitar's Avatar
The newest version up there(1.0.2) is a full installer, so you can just download it and install the whole thing. I think it will even prompt you to uninstall if you already have it installed.
Old 02-11-2006, 09:06 AM
ok.. cool. i will give it a try!
thanks!!
Old 02-11-2006, 12:21 PM
ok.. this is stange. i re-installed the plugins, along with the updates and they still are not showing up in the plugin menu.. i am a bit confused here. they should install into the correct folder. should i move them? what folder do they need to be in so that i can access them? and if so.. what file need to be moved over.
note: i tried to unistall them and "IK Multimedia" was not listed as a program on the list in the "remove program" listing.
please help me..
Old 02-11-2006, 02:11 PM
spkguitar's Avatar
In Pro Tools, Amplitube LE shows up in the "Other" category.
In the Windows uninstall menu, it shows up as "Amplitube LE".
If you're using the right installer you shouldn't have to physically move the files.
Old 02-13-2006, 05:29 AM
ok.. so i installed the plugins.. and again for some strange reason the files were not loaded into the correct folders..? ( i am using the original install disc provided with my 002). so after some snooping around i moved the files over into what i thought are the correct folders and viola.. it worked. but now amplitube/sampletank only show up in the plugin menu for one session. i can't access them in other session? huh?? anyone else have this problem?
Plugin's will not go away . . . avf925 macOS 2 04-05-2013 08:00 PM
can I trust the gain plugin's "find level" result? Lowendr macOS 0 08-07-2012 10:42 PM
Can't find Amplitube in Session paul Neathery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-25-2007 11:57 AM
Can't find installed plugin's devapro Pro Tools TDM Systems (Mac) 3 11-07-2006 09:00 PM
Amplitube?...how do I find it? kold 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-30-2004 01:03 PM
