Old 02-26-2024, 07:12 PM
QuacksMeUp QuacksMeUp is offline
Default Retain S1 control with PT in background *SOLVED*
While writing this, I solved my own question. DOH! But will post here for the sake of others.
Is there a way to retain use of the S1 (faders/soft keys) when I have clicked into say, a Finder window and PT is in the background?
Yes. WITH PRO TOOLS OPEN IN THE FOREGROUND, open EuControl Settings/Applications. "Pro Tools23Mac" (or similar) should be listed as Last Focused Application. If not already added to the Application list below that, click the + button to add it. (That was the step I was missing.)
Finally, at the bottom Lock To Application, click the checkbox for Transport (and Monitor & Control Room if desired).
Now, you'll still have S1 control of Pro Tools running in the background - while looking at other items in the foreground.
Old 02-27-2024, 09:33 AM
tope d's Avatar
tope d tope d is offline
Default Re: Retain S1 control with PT in background *SOLVED*
Thanks for the info, QuacksMeUp! :)
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Avid Control loses Pro Tools in background daeron80 Pro Tools 3 01-13-2022 07:37 AM
Can Control stay active when PT is in the background? 1m1 Avid S1, S3, Dock and Control App 3 04-07-2021 09:54 PM
Avid Control with Dock plugin presets/ background operation cronos Avid S1, S3, Dock and Control App 2 06-25-2020 08:09 AM
SOLVED: iOS 9.3.4 not compatible with Control? ha2dorff Avid S1, S3, Dock and Control App 8 08-26-2016 12:36 PM
Soundminer background transport control? reichman Post - Surround - Video 1 04-08-2011 12:47 PM
