Logic Pro 10.2 + automation does not work
I wonder if anyone else using Logic Pro X 10.2 with Eucon has troubles with using it to trigger Logic's automation (read, write, latch, touch), After upgrading Logic, I find that these soft keys do not work anymore? Thanks |
Re: Logic Pro 10.2 + automation does not work
No replies worries me. Seriously, is there any experience with Eucon and Logic 10.2? Are the two compatible or are they not? Surely someone from Avid can answer this? I need to know before buying an S3.
Well, after a lot of digging and the help of Sweetwater's people, this is the status of compatibility with Logic 10.2 and OSX Yosemite:
"Basic functionality is all there with faders, knobs, aux, plug-ins, automation, etc. I talked to a guy who has been testing it and overall it seems to work quite well, it connects right away and functionality has been solid. You can program some of the buttons on the S3 to custom Logic functions in EuCon same as with Pro Tools or other DAWs. The one problem I'm aware of is that if you instantiate a plug-in in Logic using a mouse then it doesn't show up on the S3 at this point, however if you instantiate the plugin from the S3 then it works fine. Also if you work in templates then it's fine but if you instantiate with a mouse then the plugin won't show up until you relaunch Logic. This issue is unique to Logic and we've reached out to Apple but I'm not sure what the timeframe is on resolution. Everything else seems to work quite well. " Hope this is helpful. I'm afraid I cannot document or identify the source, as it was not provided to me... isn't it a shame though that we have to hulk around all the dark corners of the Internet to get information, when all that Avid would have to do, if they cared, was respond to inquiries in places like this. -A |
Come on, fix it already! |
Well 3.3.2 didn't correct my automation problem :-(
Bump - Kyle or anyone at Avid, could you please answer this one or am I only one having this problem?
Bump - Kyle or anyone?
Trim & VCA automation now in Logic X | Ru_C | General Discussion | 2 | 03-02-2015 10:04 AM |
Logic pro and logic pro x doesn't work after mavericks | Sanderb | Artist Series | 3 | 12-20-2013 12:13 PM |
FCP + Logic + PT automation | mellow1998 | Post - Surround - Video | 3 | 06-20-2008 04:21 PM |
Exporting Pan Automation to Logic or other workflow | tlloren | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-09-2008 04:37 PM |
tdm logic plug in automation in logic 7? | quincygriffin | Pro Tools TDM Systems (Mac) | 5 | 05-23-2005 09:08 AM |
