Old 04-17-2007, 12:18 AM
Howardk Howardk is offline
Default > Amp Farm does not pass audio
Had a strange problem today tracking. I setup 2 amp farm tracks to record guitar parts. One quit working, meters move but it would not pass audio. I removed the plugin and reinstaniated and it worked, but that quite again a few minutes later. I shutdown ProTools and restarted and all with fine for a couple hours. Different tune hours later and same problem occurred. . . although intermettient it seems the cause was having 2 tracks in record with Amp Farm, and one will just stop passing audio out of the blue.
PT 7.3.1 CS2
HD3 Accel
G5 2.5GHZ 4GB RAM
OS X 10.4.8
Latest versions of all plugins
...for system configuration info see my profile
(Click on member name)
Old 04-17-2007, 04:08 AM
PhilBuckle PhilBuckle is offline
Default Re: > Amp Farm does not pass audio
Same kind of thing happening here.
Sometimes after openiing a session I will get 1 or 2 Amp Farms not working. Reinstantiating always works for me.
Other times one Amp Farm will go ballistic and distort like a Big Muff on steroids.....which should sound good but.....
Once again reinstantiate.
Amp Farm is just a bit flakey and old............hey it's vintage after all!
G5 Dual 2.7 OS 10.5.6 HD Accel 2 192+96 I/O
http://philbuckle.com/
Old 04-22-2007, 06:32 AM
InjuredEar InjuredEar is offline
I have the same problem mentioned in an earlier thread here.
are you using Amp Farm 3 or Amp Farm 2?
I'm using Amp Farm 3 and run into the muting problem.
It seems one workaround is to stay away from the old presets from Amp Farm 2 that are in the Amp Farm 3 presets menu.
Not really a feasible idea if you're opening up old sessions with multiple instances of Amp Farm.
That's all I got for suggestions. I find myself reaching for the Sansamp PSA-1 and Amplitube more often because of the same problem.
Greg
original audio still on the trk after another pass [email protected] Pro Tools 9 3 12-22-2012 02:35 PM
MBOX2 Audio Pass-through Baldster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-11-2011 03:27 AM
BUG! PT10 some aux inputs won't pass audio digidesigner Pro Tools TDM Systems (Win) 1 12-02-2011 10:58 AM
High pass and low pass filter for distorted guitars? adamqlw Eleven Rack 13 09-30-2011 10:35 AM
> Aux does not pass audio Howardk Pro Tools TDM Systems (Mac) 4 04-20-2007 07:53 AM
