Old 01-11-2012, 09:11 PM
Dizzi45Z Dizzi45Z is offline
Default Set Minutes and seconds start time
Is it possible to select a point where you would like to start the counter for Minutes and seconds. For example, if you wanted to have the song in your project start right at the 0:00 minutes and seconds even though it doesn't really start until after 2 bars of counting in?
I've noticed that there is renumber measures and set current time code position, but I can't find anything that lets you set minutes and seconds. I'm thinking that maybe this isn't possible in Pro Tools as one time based ruler probably has to stay constant.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 01-11-2012, 10:05 PM
elicious elicious is offline
Default Re: Set Minutes and seconds start time
use your time code ruler
and reset that to 0:00:00.
e
ihatetyping
Old 01-12-2012, 06:37 AM
e
Thank you. This is a workaround that isn't too bad. But does that mean the answer to my question is no?
160 GB RAM
macOS 11.7.4
Old 01-17-2012, 01:17 PM
mbahnmil mbahnmil is offline
I'll take it. It would be nice if you could pick which ruler to be your fixed base and allow other rulers to be reset over it. But like Dizzi said, it's a decent workaround.
Old 01-18-2012, 07:38 AM
brianiac5150 brianiac5150 is offline
EDIT: 01/18/12 | 7:41 PM EST
Sorry...I was completely off on my reply, so I simply edited the comment as a removal. Hope you've got this worked out.
THoM Facebook
Old 01-18-2012, 08:39 AM
Carl Kolchak Carl Kolchak is offline
No, you cannot re-position the Hours/Minutes/Seconds ruler.
I believe this is due to the fact that Pro Tools is Sample based, and as the samples accumulate, they correspond directly to a specific moment in time if you will _ sample rate = X samples per second.
i.e. in a 44.1k session :
a location 1/2 a second in from the start of the session (0 samples) would be measured at 22050 samples.
a location 1 second in from the start of the session would be measured at 44100 samples.
a location 2 seconds in from the start of the session would be measured at 88200 samples etc.
It's not really practical to talk in such microscopic scales, and such huge numbers - so Hours/Minutes/Seconds it is.
MIDI and Timecode are relative scales of measurement (as is sample rate, though once it is set for the session, it is effectively fixed) so you are free to renumber and rescale those, continually in the case of MIDI.
It might seem like a simple task to translate any sample position to any specific hour, minute or second - I'd have to leave that up to Avid to determine if it's an issue, and if it's a feature they get a lot of requests for.
It could be handy.
Old 01-18-2012, 09:27 AM
Kasper Kasper is offline
e
↑↑yup↑↑
Why doesn't this work for you?
What are you trying to do that can't be done with the TC ruler? (set it for 30 or 29.97 drop and it's real-time accurate)
kasper
Old 01-18-2012, 01:02 PM
Kasper,
It works, you just don't get the milliseconds since you get frames instead. But you are right, it isn't a bad workaround.
160 GB RAM
macOS 11.7.4
Old 01-18-2012, 03:37 PM
Originally Posted by Dizzi45Z View Post
Kasper,
Still not sure of your application, maybe a BPM calculation?
Anyway, if you call up an AudioSuite plug of Time Compression/Expansion or Time Shift, you can see multiple readouts of different time scales.
You can measure length in ms, but still keep your main ruler on TC (for example)
Doesn't change your start time dilemma, but perhaps a help.
kasper
Old 01-20-2012, 09:21 AM
dsetaro dsetaro is offline
e
I am not sure how you reset the TC ruler to zero. Can you explain? thanks
computer randomly freezing for a few seconds to several minutes audiogeekzine Pro Tools M-Powered (Win) 2 09-30-2010 07:41 PM
Recording takes 5 seconds to start ! ElMajdal Pro Tools TDM Systems (Win) 11 12-17-2009 03:33 AM
Transport takes 5 seconds to actually start bunderson Pro Tools M-Powered (Win) 1 07-15-2008 08:29 AM
PT delays everytime i start recording (about 4 seconds) mbauer1 Pro Tools TDM Systems (Mac) 3 11-17-2007 07:16 PM
Modifying the Minutes:Seconds Ruler Philthy Pro Tools TDM Systems (Mac) 3 10-30-2001 12:40 AM
