Old 10-03-2022, 09:33 AM
borwick.alex borwick.alex is offline
Default 2022.9 Can't grab MIDI notes
Hi all,
Just wondering if anyone else is having a similar problem with PT 2022.9, or has a solution?
For some reason I can't grab/move MIDI notes at all anymore, either click-and-drag with the mouse, or using Alt to duplicate a note! Someone please tell me I'm doing something stupid, or there's a new option somewhere in the preferences?
I also can't edit multiple MIDI notes the way you used to be able to: Cmd-A to select all MIDI notes, and then you were able to edit all their lengths! This isn't working any more for me :-(
Any leads much appreciated.
Cheers!
Old 10-03-2022, 09:36 AM
Default Re: 2022.9 Can't grab MIDI notes
Also can't drag Note velocities up or down either.....
Old 10-03-2022, 01:26 PM
Pretty sure this is a known issue. 2 possible solutions:
1-change midi/instrument tracks to samples(instead of ticks)
2-save>close>re-open the session
Old 10-03-2022, 07:48 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
+1 for samples instead of ticks. I believe this only happens in older sessions opened in 22.9. This workaround has also solved ARA issues for me in older sessions. Old sessions don't seem to translate well. A cursory midi test in a brand new 22.9 session here didn't seem to produce those known midi issues.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 10-03-2022, 08:42 PM
jeff markham's Avatar
jeff markham jeff markham is offline
I've run into this a couple of times with older sessions and I worked around it by making a new session and then using File->Import Session Data .. and then importing the old data in. That seem to work around the issue.
Must be some session compatibility thing.
Old 10-03-2022, 11:13 PM
simonator simonator is offline
One more vote for tick to samples.
One quick fix that sometimes (not always) works: Reconsolidate the bad clip to create a new version. I've seen this with notes that finish outside the clip end.
Old 10-04-2022, 01:39 AM
Amazing, thank you! Solved it. What a relief.
Old 10-04-2022, 08:08 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi i can't reproduce here with new session . Everything is working a expected. So i think what Jeff said is the best solution.
Sent from my SM-G991U using Tapatalk
Avid Carbon Interface
Protools Ultimate
Old 10-04-2022, 05:09 PM
trevvahhh trevvahhh is offline
I have this bug too, 2022.9, Monterey 12.6
Brand new session in 2022.9, two audio tracks one midi track
changing to samples and then back to ticks fixed it, but doing that a lot is going to get annoying
Old 10-04-2022, 05:33 PM
lesbrunn's Avatar
This bug has been around since 22.6. I expected it to be fixed in 22.9, but it's still there. It also affects ARA sometimes, as in frozen blobs. Switching to samples always solves it. I haven't started any fresh sessions yet in 22.9, but I don't expect to encounter it. I strongly believe it only happens in older sessions. I haven't had time to investigate thoroughly, so I will stand corrected if I'm wrong about this.
Can't select MIDI Notes after Quantizing them in 2022.6 [PT-289219] Dizzi45Z Pro Tools 93 10-18-2022 08:17 AM
START CLICK GRAB (PC) CTRL CLICK GRAB (Mac) Kris75 Tips & Tricks 2 07-23-2013 09:53 AM
midi copy/duplicate: 7.4 can't grab 1st quantized note glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 12-16-2008 07:33 AM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
GRAB the MIDI KeyBoard in the Edit Window- scroll gollywillickers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-12-2006 11:41 AM
