Old 05-31-2023, 09:23 AM
idris idris is offline
Default Video sync stability
I've been doing some tests with audio/video sync, much in same way the Syncheck used to work - 1 frame of 1kHz tone concurrent with 1fr white flashes on a video screen.
I'm running my video output, via a Blackmagic PCI card in a Thunderbay expansion crate, and then via HDMI to a domestic grade Toshiba LCD screen.
I've started from an H264 (created for me by a video editor) and have placed audio sync pips on a mono PT track.
The results I'm getting are quite variable: with flashes/pips every 2 seconds the measured sync can vary by about a frame (max to min).
I'm interested to know whether there is something inherrently unstable about my PT and video hardware, whether the H264 is the weak link or whether it's my measurement ... or whether that's reasonably stable.
Any thoughts?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM
Over 30yrs experience in pro-audio - mostly for picture.
Old 05-31-2023, 09:59 AM
its2loud its2loud is online now
Default Re: Video sync stability
H264 is most definitely your weakest link. Try testing with DNXHD or ProRes
Old 06-02-2023, 02:35 AM
Yes that's normal for a system that isn't genlocked. But using H264 doesn't help lowering the span either.
See here:
https://www.pro-tools-expert.com/pro...ools-explained
(BTW: the illustration in that article is missing an important connection: the sync signal going to the video hardware from the generator. Without it it won't work)
But with your hardware you won't be able to achieve 100% sync so you'll have to live with up to +- 1 frame of sync span for every time you hit play.
Old 06-15-2023, 09:14 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Hi Idris,
If you have an iPhone you can use Catchin' Sync to test your system lag.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 06-16-2023, 01:07 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
I frankly still don't understand why people continue intentionally hurt themselves?
Its been said and written and white papered on every corner: use DNxHD36 or ProRes Proxy for most reliable sync.
An H.264 is a quick delivery codec and is NOT suited for work with Pro Tools. Its nature makes it drifting in unpredictable way even when trying to use it within the proper genlocked system.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
HTML code is On
Video newbie: sync'ing wild shot video with concert audio edwinh Post - Surround - Video 2 08-21-2022 06:11 AM
[VIDEO] Eucon vs Command8 fader stability test jacko Avid Pro Mixing General Discussion 13 09-29-2015 11:41 PM
Keeping Laybacks in Sync (delay compensation and Video sync offset) edit machine Pro Tools TDM Systems (Mac) 6 11-15-2010 11:33 AM
Video & General Stability Problems soundcreative 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-25-2010 11:39 AM
Video Sync & consumer video decks binaural General Discussion 2 07-19-2000 08:20 AM
