"-" key no longer switches MIDI track from clips to notes SOLVED (duh)
In the past (up to 2019, roughly), using the "-" (minus) key would switch a MIDI track from notes to clips mode - really handy if you're working entirely in the Edit window. It seems to have disappeared, at least since PT2019.
I've found a few threads asking about this, but without any answers. Has it permanently vanished? It's a small, but very useful and time-saving command. It doesn't work on my M1 Mini/Big Sur/PT 2021.7 machine, either. EDIT: Found the issue. It only works on a track that you're actually in - i.e., the cursor is clicked and flashing in a particular track. Doesn't matter if the track itself is selected, you need to be actively editing the track, which makes sense, and, quite possibly, was how it worked in the past. Leaving this up in case someone else is having a brain fart on this "problem". Thanks, Myles
System 1: 2023 Mac Studio 64Gb RAM, OS 13.6, PT Native 2023.12, Metric Halo ULN-8, LIO System 2: 2021 M1 Mini 16Gb, OS 13.6, Native 2023.9, MH ULN-8 4d http://www.mylescochran.com Last edited by tooold; 12-16-2021 at 02:13 AM. Reason: Solved |
Re: "-" key no longer switches MIDI track from clips to notes SOLVED (duh)
Thanks for sharing the solution. I was not even aware of that shortcut
Yes! That is a very useful shortcut. Glad to know it!!!
Steve
Steve Shepherd Extreme Mixing |
Glad it was helpful. It saves a lot of mousing around.
Myles
System 1: 2023 Mac Studio 64Gb RAM, OS 13.6, PT Native 2023.12, Metric Halo ULN-8, LIO System 2: 2021 M1 Mini 16Gb, OS 13.6, Native 2023.9, MH ULN-8 4d http://www.mylescochran.com |
Difference between "Midi Studio Setup", "Midi Input Devices", and "Midi Controllers"? | GOOOTOOO | Pro Tools 2020 | 5 | 04-01-2020 01:23 PM |
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" | EdgarRothermich | Pro Tools 12 | 2 | 10-04-2017 02:18 PM |
Midi Clips View Problem, option + "-" keyboard shortcut broken | kingtinker | Pro Tools 10 | 5 | 09-25-2016 01:47 PM |
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] | andrew24c | macOS | 4 | 07-23-2014 07:21 PM |
HELP, digital-like "clips" in midi track???? | guy.fi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-24-2008 07:28 AM |
