Old 06-08-2023, 02:49 AM
LDS LDS is offline
Default Re: Working with 32bit Float Files
It is my understanding (and I may be wrong) that Carbon outputs 32-float. Carbon AD performance is not so spectacular. It is only 126dB, which is not bad, but the point of 32bit converter is kind of DigiDesign 192 soft clip with steroids, as in not clipping.
24-bit has theoretical maximum of 144.5dB so otherwise advertising 32-bit makes no sense. There is still 18.5dB headroom without.
With that said, 20bit has theoretical maximum of 120dB and for that reason 24-bit fixed makes sense. 32-bit fixed point? No. Give me a converter with more than 192.5dB dynamics and I believe.
The Carbon is 32-bit integer. It clips at 0dBFS.
Old 06-08-2023, 02:59 AM
So it is only AVB streaming that is float? In that case 32bit AD conversion is nonsense, it still has less than 24bit dynamic range. I stand corrected.
HTML code is On
32Bit Float with Pro Tools 11 RichS Pro Tools 11 3 04-13-2017 06:38 AM
Recording: 24bit vs. 32bit float WombatStudio.Org Tips & Tricks 55 10-05-2014 03:41 PM
Using 32bit Float Point DonaldM Tips & Tricks 52 06-27-2014 01:44 AM
32bit float (16.8)/(.24) import PROBLEM donrey Pro Tools TDM Systems (Win) 14 05-20-2006 12:05 PM
The 32bit float advantage ptnerd Pro Tools TDM Systems (Mac) 22 11-19-2005 10:26 AM
