Old 12-23-2023, 02:23 PM
off the wall's Avatar
off the wall off the wall is online now
Default New Markers Window in 2023.12 broke selecting regions
In the new Marker window on PT 2023.12, you can no longer click a marker, then shift click a second marker to create a selection for a bounce.
You must click/shift click the markers on the timeline. It no longer selects anything when doing this in the Marker window itself and your bounce winds up with some nonsensical start and stop points.
Thinking it has something to do with the new ability to select multiple markers in the window for other operations now.
Anyway, it caused me to bounce of bunch on junk today before I realized what was happening.
offthewallproductions
Old 12-23-2023, 03:01 PM
zeeman zeeman is offline
Default Re: New Markers Window in 2023.12 broke selecting regions
Yea this threw me for a minute but i think whats happening is you have to click in the far left column now, right under the new view filter. then it works as normal. Your right, if you click the marker name, Like it has always been, nothing happens. no selection.
Hope this helps
MAC OS 13.6.1
Mac Mini M2 16gig Ram
PT 2023.12
Lynx Aurora 16n Thunderbolt
Old 12-23-2023, 03:11 PM
Originally Posted by zeeman View Post
Yea this through me for a minute but i think whats happening is you have to click in the far left column now, right under the new view filter. then it works as normal. Your right, if you click the marker name, Like it has always been, nothing happens. no selection.
Hope this helps
AWESOME! thank you. Clicking in the far left column has the same behavior as previously clicking anywhere on the marker. ie you can Click/Shift Click on markers in the Marker Window and get a valid bounce selection as before.
Old 12-24-2023, 06:29 AM
Also. if you click the little Link button in the upper left hand corner,you then can click the marker name like the old days. For me having that button checked is causing me an instant crash if i right click a marker to edit it when that marker contains a window configuration, which i use all the time. So for me, i do not check the link button and all works.
MAC OS 13.6.1
PT 2023.12
Old 01-10-2024, 10:15 AM
tumbador tumbador is offline
Thanks for that!
I hope we can have a "classic" version of the memory location window...
Hope this helps
Old 01-15-2024, 06:02 PM
Jeff D. Jeff D. is offline
Hope this helps
d
Thank you for that! I bounced a bunch of nothing today!
It is tough to change muscle memory after a decade plus of making a start and and and end marker on every session, then shift-clicking them to bounce the session without a thought.
www.jephthastudios.com
Markers not in Memory Location window after 2023.12 update sc0tt0 Pro Tools 6 01-10-2024 02:53 PM
2023.9 - Edit Cursor Screen Artifacts When Selecting a Clip audiogamble Pro Tools 29 11-16-2023 06:00 AM
PT 2023.6 broke Avid Control app on iPad HearInc Avid S1, S3, Dock and Control App 23 09-23-2023 11:03 AM
Selecting in regions list doesn't select in edit window peytontodd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-15-2011 02:33 PM
Selecting between markers from 10 and above. DannyVanSpreuwel Pro Tools TDM Systems (Mac) 8 10-07-2000 11:30 AM
