DIGI 003 Rack "Powering Down" at PT Launch
Hey guys,
I tried searching but couldn't find anything on this. I have a DIGI 003 Rack system running PT 8.0.3. In the past couple months or so, the rack unit has "powered down" once PT has launched. I have to turn the rack unit off then back on again to get things going. But that of course causes other communication problems between the rack and PT so I end up having to shut down PT and start over. Has anyone else had this problem? Any ideas? Thanks. |
Re: DIGI 003 Rack "Powering Down" at PT Launch
That's odd for sure. Which OS are you running? Have you tried another firewire cable(they can fail for no reason).
Running Win XP (32Bit). Yeah it's wierd...I guess I'll try the firewire cable.
DO NOT hot-swap the firewire cable!!!!! Turn EVERYTHING off first!!!!!!
Thanks for the tip sw rec!
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I'm having this problem with my 003 console. Right in the middle of the session the console will just go offline.
Could it be a driver update or something to correct this? I have to close PT 8 and restart and then it works fine, but it may randomly go offline. Thanks! |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
002 rack "clicks" and Windows beeps when "Setting Up Midi" or | sw0mgt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-03-2012 03:42 PM |
All of a sudden PT 9.0.2 Not "seeing" Digi 002 Rack | Hollow Body | Pro Tools 9 | 4 | 06-19-2012 02:01 PM |
PROBLEM WITH DIGI 003 RACK "CoreMIDI.Framework" | DjRybe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-18-2010 11:29 PM |
Cant find Licence # in "My Digi" for "Reason" | jefflennan | MIDI | 1 | 09-08-2009 12:32 PM |
