Old 11-27-2021, 02:53 AM
pavoni pavoni is offline
Default Recording drop ins with mixed MIDI and Audio tracks using playlists
I'm often recording jazz band sessions where I want to record the piano MIDI as well as the direct piano sound - because I can use a better MIDI piano sample when mixing.
I usually use playlists when the band want to drop in and fix something.
So I use 'duplicate playlist' on a group of tracks - and all is good.
EXCEPT MIDI.
It seems when you duplicate a midi playlist - and record over it - Protools will either destructively overwrite the previous clip - or merge the notes of the second take into the clip (depending on whether you have midi merge turned on).
What I'd like / expect is for Protools to keep my old midi clip intact - and create a new one.
I guess when I duplicate audio playlists - I could then delete the midi clip from the new MIDI playist. Or I could use "New Playlist" for the MIDI track when I use "Duplicate Playlist" for the audio tracks- but it seems seems a bit clumsy (and very easy to mess up the previous MIDI clip).
Am I missing something - does anyone have a good way to do this?
Old 11-27-2021, 04:47 PM
Top Jimmy's Avatar
Default Re: Recording drop ins with mixed MIDI and Audio tracks using playlists
It sounds like you have mirrored midi editing turned on. Look in the Options menu for Mirrored MIDI Editing and turn it off.
James Cadwallader
Old 11-28-2021, 01:49 AM
You're right - I've turned that off and it now works like I hoped.
Jimmy - you're a lifesaver - thanks so much!
Export Playlists to new audio tracks Extreme Mixing Pro Tools 14 10-19-2021 03:31 PM
Midi tracks playlists now!!! Prabha Pro Tools 2018 1 11-21-2018 03:56 AM
Recording the Audio from MIDI tracks Cavet Your Eruptor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-02-2006 10:20 PM
EASY! recording midi to audio tracks jamesinseattle MIDI 13 07-01-2004 09:07 AM
Recording Midi as actual Audio Tracks? HELP! markgr82nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-14-2001 10:48 AM
