9 As End of the Line
I've got an early MacPro (1,1), 003, PT 9 with Music Production Toolkit and am running Snow Leopard. And I'm very happy with it. When i recently ran into some computer troubles I contemplated getting a new machine and checking out PT11. But the cost and the lack of compatibility of plug ins, etc really make me want to stick with what I have. It works great and it more than enough for me. I started on a cassette 4 track so this is am amazing rig for me.
If I want to stay on PT9 for the next 5 years is my best option just to keep this computer running Snow Leopard? I have a cloned FW drive that I can boot from as back up. Anyone running a solid state system drive on an older machine like mine? Worth doing? I have two additional drive slots I'm not using. Also, if anyone has advice. When I push the power button sometimes I get one loud beep and no power. And then it usually comes on with a second or third attempt. I understand this is supposedly an issue with RAM. I ran Rember and it said everything was good. However, at times I notice if I check my computer info sometimes it says I have 7 GB and sometimes it says 6GB. I recently took out and reseated all the modules. I had added additional RAM when I got PT9. Thanks
One Mad Son The only difference between me and a madman is that I am not mad S. Dali |
Re: 9 As End of the Line
IMHO...That's just fine. There are many people professionally using PT 7 and some that feel it was one of the best. If 9 works for you then it works. An individuals production needs will determine the platform. I looked closely at 11
and if honest with myself and my production needs, must say I do not need it. I want it of course. @v@:) |
Solid-state drive makes Snow Leopard boot like a beast
Upgrading to 10 is a really great idea eventually because of the disc cache And with all the control 24's and pro controls out on the used market you could probably get you an awesome control surface to use with 10 as well
protools 10 clip gain line /volume line | alidav | Pro Tools 10 | 3 | 03-09-2013 05:21 PM |
HELP! QT movie will not line up on frame line | amptbuddy | Post - Surround - Video | 4 | 11-28-2010 10:43 PM |
EQing dialog line by line | eyrelight | Post - Surround - Video | 1 | 09-16-2010 06:49 AM |
Line In Line Out Monitor Problem | Connecticut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-02-2010 07:40 PM |
Mic/Line and Line inputs on Mbox2 Pro | DAT11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-16-2007 08:06 PM |
