Old 12-01-2021, 09:08 PM
pi-town pi-town is offline
Default Missing Files
Audio File(s) are missing...
I have dragged and dropped them into several different tracks on a session, then saved and closed Pro Tools numerous times. As soon as I open that session, I am greeted with this message.
This is really not what I expected from the "industry standard"
Old 12-02-2021, 06:19 AM
junkgear's Avatar
junkgear junkgear is online now
Default Re: Missing Files
Hi and welcome to the forums.
First of all, which version of Pro Tools are you using?
Second, check to see that you have the option to automatically copy files on import selected.
You can also read through the Pro Tools Reference Guide for help with importing audio files. See Chapter 21 for information.
If that doesn't help, give us a little more information about how you are importing these files, like from where, to where and we will have a better shot at helping you out.
Will
System Details
Old 12-02-2021, 07:09 AM
Good advice above, but here's a little more:
1-even with the preference set to automatically copy files on import, I have still had this issue once or twice.
2-one method to help avoid this is to(BEFORE importing/dragging into the session), copy the files into the session folder and import/drag from there. Doing this means that you(and the session) know exactly where the audio came from.
Its up to you whether you drop the files in the main session folder or into the sessions' Audio Files folder as either works(a really full Audio Files folder can make it hard to locate a few files for import). Using the Import>Audio Files method is generally safer than dragging files from other locations(especially if you are dragging from an external drive that will be disconnected)
Old 12-02-2021, 08:45 PM
Thank you @junkgear
For any other curious minds out there, the feature mentioned above can be found by navigating to:
Setup > Preferences
Then by clicking the "Processing" tab
You'll find the option to "Automatically Copy Files on Import" there.
Honestly, a box that seems like it should already be clicked by default.
Regardless, thank you all for the help!
(I switched to PC and couldn't use Logic anymore so... here I am)
Deleting files from clip list and missing files colinato Post - Surround - Video 1 10-22-2013 09:52 AM
Missing fade files, missing audio in resaved sesssions drygruo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2010 04:56 PM
All Sessions using SDII files are missing all audio files and won't relink bigmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-18-2009 12:54 PM
missing audio files are actually not missing tomcat Pro Tools TDM Systems (Mac) 3 12-24-2006 02:25 PM
Missing Fade files become missing audio files? Tim R. Pro Tools TDM Systems (Mac) 11 06-21-2004 09:48 AM
