Old 07-25-2011, 01:25 PM
OneMadSon OneMadSon is offline
Default 003 stays "offline" in PT
When I launch PT is launches fine but my 003 stays Offline and my sessions that I open are screwy with the choices for my inputs. I can play the session and hear it via my computer speaker but can not record, etc.
If I close out of PT and launch safari and play a youtube video the 003 comes online and the sound plays through my monitors.
Any ideas?
One Mad Son
The only difference between me and a madman is that I am not mad S. Dali
Old 07-25-2011, 01:36 PM
Default Re: 003 stays "offline" in PT
also, when PT opens a session it says "Your I/O set up has changed since your last session. Some inputs have been made inactive"
One Mad Son
Old 07-25-2011, 03:36 PM
one other thing is that when i get the report for what has changed it says all the tracks other than Analog 1 and 2 are NA. For specific tracks it says the following.
"Track "Audio 1.01" (audio) input "Analog 8" has been made inactive because the input path is currently not available."
One Mad Son
Old 07-25-2011, 06:15 PM
DigiTechSupt's Avatar
Help Us Help YOU - READ THIS before posting.
Avid Audio Tech Support
Support FAQ
Old 07-25-2011, 06:49 PM
danander11 danander11 is offline
It's likely that you need to open the playback engine in the setup tab and change back to the digi003..
If you started PT without the 003 being on it reverts to whatever is available and stays that way until you change it.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 07-26-2011, 05:31 AM
That did the trick. So this would occur if I started Protools without the 003 on? I know I've done that before and what has happened is that I get a message saying something like "there is no PT hardware for the system so PT won't launch". This appears to be different behavior.
Thanks.
Intel Dual 2.66
OSX 10.6.3
7 Gig Ram 667 Mhz DDRs FB-DIMM
PT 9.0
One Mad Son
Old 07-26-2011, 09:27 AM
Park Seward's Avatar
Park Seward Park Seward is offline
With PT9, you can run with no Avid hardware attached, thus the change in prompts.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 07-26-2011, 02:58 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Also remember when PT is booting, hold down the N key to open up interface window to select your interface.
Mbox Pro 3 blue light stays on but has the status of "Hardware not connected" Focuret FireWire & USB Audio Interfaces (Mac) 1 01-15-2014 12:18 AM
Edit softkeys not possible, Eucontrol stays "in focus" johngar Artist Series 6 05-20-2013 06:12 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Main unit of my D-control says "offline" corbittclam ICON & C|24 2 06-09-2011 12:56 PM
What's the difference between "online" and "offline" editing ? stuu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-21-2002 03:46 PM
